Soldering a TA5 to 3.5mm adapter cable
bendybones
Hi All,
I need get a custom cable made to adapt the TA5f return plug of my Nomad umbilical to the unbalanced  3.5mm return input of other mixers such as 552 etc.
The Nomad return input pin out is as follows.
Pin 1 - Ground
Pin 2 - Channel A (Left) ( + )
Pin 3 - Channel A (Left) ( - )
Pin 4 - Channel B (Right) ( + )
Pin 5 - Channel B (Right) ( - )
Is it fine for me to leave 2 of the pins on the adapter cable's TA5 male not connected?
Like this:
TA5m Pin1 _ Gnd _ Sleeve
TA5m Pin2 _ A(+) _ Tip
TA5m Pin3 _ nc
TA5m Pin4 _ B(+) _ Ring
TA5m Pin5 _ nc
Another option would be to divide the braided shield into 3 strands, and attach 1 to each of the three gnd pins. I've resorted to this approach lately, as I find the individual tinned strands add a bit of rigidity. It's also a bit easier (and I feel safer) than crossing adjacent hot pins.
6 in 1...
