Dennis Kersten Posted April 14, 2014 Report Share Posted April 14, 2014 Dear colleages, I would like to shortly discuss an R4 workflow idea with you. Sometimes I do these ENG straight to camera gigs. I use a cooper cs104 mixer to mix straight to camera (Allthough I use the camera as a 2-channel iso track recorder). And I use the R4 as a back up recorder. My idea is to make a multi cable for the R4 which carries 2 outputs and a return to the camera and maybe a video signal. This way I can skip the cs104 mixer (and loose some weight in the bag). The R4 has outputs and return on mini xlr. Only drawback I see now is that it is not possible to fade to zero with the channel gain and that the recorder doesnt have a -20 testtone. The testtone could be solved with a playable testtone file on the recorder. What are your thoughts on this? Quote Link to comment Share on other sites More sharing options...
johngooch Posted April 14, 2014 Report Share Posted April 14, 2014 Bringing the return from that camera into the R4 would require you to record that return track. No way to monitor a track without recording it. So you'd probably want to throw away that track. Could cause editorial confusion. Quote Link to comment Share on other sites More sharing options...
Richard Thomas Posted April 14, 2014 Report Share Posted April 14, 2014 This may do the job:http://www.remoteaudio.com/return_box/ (you still can't mix to zero though- I tend to use it with the SX-M32 most of the time for this reason) Quote Link to comment Share on other sites More sharing options...
daniel Posted April 14, 2014 Report Share Posted April 14, 2014 or http://www.richmondfilmservices.co.uk/equipment/headphones-and-accessories/HED031.html Quote Link to comment Share on other sites More sharing options...
Dennis Kersten Posted April 15, 2014 Author Report Share Posted April 15, 2014 Thanks John didn't realise that. Thanks Richard & John. Interesting! I think I'm buying a mix pre D and make a multi that can go with the mixpre and have a tape out to the R4. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
