RadoStefanov Posted May 22, 2014 Report Share Posted May 22, 2014 Yep. Dragon does not sync... I tried every voltage from ERX. Hard line from maxx. Denecke jam box...nothing... Good job RED...learning from past mistakes much? Quote Link to comment Share on other sites More sharing options...
Richard Lightstone, CAS Posted May 22, 2014 Report Share Posted May 22, 2014 On my show, 2 Denecke SB-3's on the Red Dragon cameras and all is working fine? Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted May 22, 2014 Author Report Share Posted May 22, 2014 Richard, how old is tour SB3? Mine is a new one and jams epic no problem. My friend's sb3 is old one and does not jam the epic. I think denecke revised the voltage on their sb3s. I just found a way to jam the dragon. After trying erx " all voltages" and denecke sb3, i plugged my slate. Initially the dragon did not sync but when I restarted the slate it did... magic ... Quote Link to comment Share on other sites More sharing options...
Richard Lightstone, CAS Posted May 22, 2014 Report Share Posted May 22, 2014 I stopped supplying Lock-it boxes 5 years ago. I have them supplied by the camera rental house - so any issues with them are theirs! I'm not really sure when these SB-3's were manufactured. Quote Link to comment Share on other sites More sharing options...
studiomprd Posted May 22, 2014 Report Share Posted May 22, 2014 I think there is another movie coming out about how to train your dragon... RL: " supplied by the camera rental house - so any issues with them are theirs! " Quote Link to comment Share on other sites More sharing options...
Constantin Posted May 22, 2014 Report Share Posted May 22, 2014 I had a one day shoot with a Dragon Monday. Synced fine with a slightly older Lockit. Directly into the built-in TC port. It was the red lockit, maybe that works best with a RED Quote Link to comment Share on other sites More sharing options...
JP Fonseca Posted May 22, 2014 Report Share Posted May 22, 2014 Did a feature last year with 4 Dragons with Ambient Lockits (ACL 204). Zero problems. Quote Link to comment Share on other sites More sharing options...
Charlie Parra Posted May 22, 2014 Report Share Posted May 22, 2014 Richard, how old is tour SB3? Mine is a new one and jams epic no problem. My friend's sb3 is old one and does not jam the epic. I think denecke revised the voltage on their sb3s. Hi Rado, We have not changed the output level of the SB-3. It has always been the same. There are some SB-2 that have a hotter output, but not many of them are out there. Best Regards, Charlie Quote Link to comment Share on other sites More sharing options...
old school Posted May 23, 2014 Report Share Posted May 23, 2014 I stopped supplying Lock-it boxes 5 years ago. I have them supplied by the camera rental house - so any issues with them are theirs! I'm not really sure when these SB-3's were manufactured. I never supply them for this very reason. Also I feel the rental should be a camera or DIT thing. CrewC Quote Link to comment Share on other sites More sharing options...
Matt Martin Posted May 23, 2014 Report Share Posted May 23, 2014 One day shoot with the Dragon today. It would not recognize the incoming code. Tried the ERX at all voltages, tried jamming directly from Nomad BNC using camera department's RED made TC I/O cable, no luck. Even tried cross jamming 23.98 with 29.97 and it still did not take ( someone mentioned this worked for them in another thread). I did not think to try jamming directly from my denecke Ts-2(sb). I am wondering if that would have worked. Also, we could not get audio to work either. In the audio menu, all audio drop down menus would not drop down and were blank. Obviously a camera firmware issue. Quote Link to comment Share on other sites More sharing options...
Marc Wielage Posted May 23, 2014 Report Share Posted May 23, 2014 Yep, this is a hot topic on the Red User forum. All you can say is, "this is a camera problem" and refer them to the manufacturer: RED Customer Support (949) 206-7900 https://support.red.com/anonymous_requests/new Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted May 23, 2014 Author Report Share Posted May 23, 2014 Well my workaround works. So in the future I will just charge production for a second slate. Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted May 23, 2014 Author Report Share Posted May 23, 2014 Hi Rado, We have not changed the output level of the SB-3. It has always been the same. There are some SB-2 that have a hotter output, but not many of them are out there. Best Regards, Charlie thanks. do you think it is possible my friend's sb-3 needs to go back for a repair? Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted May 23, 2014 Author Report Share Posted May 23, 2014 I found another way: switching my slate from read to write mode it jams the camera and keeps in sync... Quote Link to comment Share on other sites More sharing options...
Charlie Parra Posted May 23, 2014 Report Share Posted May 23, 2014 thanks. do you think it is possible my friend's sb-3 needs to go back for a repair? I doubt it, but we will definitely check it out for him if he wants to be sure. I found another way: switching my slate from read to write mode it jams the camera and keeps in sync... Thant's interesting. The TC level on slates is the same as our sync boxes. Real strange....... Charlie Quote Link to comment Share on other sites More sharing options...
al mcguire Posted May 23, 2014 Report Share Posted May 23, 2014 >Real strange.......< All part of the Red Audio Experience Quote Link to comment Share on other sites More sharing options...
bwfmixer Posted May 24, 2014 Report Share Posted May 24, 2014 Yep. My "fix" was jamming directly from nomad sending 30DF to 23.97 on the cam. Once it locked I plugged in my ERX on the correct TC and it maintained sync until wrap. Took us hours of troubleshooting, not to mention sneers from the DP (my friend) that my "new" recorder didnt work properly. Quote Link to comment Share on other sites More sharing options...
studiomprd Posted May 24, 2014 Report Share Posted May 24, 2014 bwf: " 30DF to 23.97 on the cam. " 30DF 30 to 23.976 Quote Link to comment Share on other sites More sharing options...
Srgtfury Posted May 24, 2014 Report Share Posted May 24, 2014 Hello Marc, bwf, dear friends & Hon. Senator Mike! Fury has spent a fair amount of time, with RED tech and the determination is that the is a DRAGON hardware issue. To be sure, it is, at once, vexing and perplexing, to all. The above workarounds , while meritorious, are not facile enough, for routine field applications. Fury has been informed, by RED tech, that they continue to work on this issue, which admittedly has taken longer than all had hoped... In short, it depends... Fury shall report back, here, if new developments warrant. Thank you very much Fury Quote Link to comment Share on other sites More sharing options...
studiomprd Posted May 24, 2014 Report Share Posted May 24, 2014 and thank you very much, Sarge Quote Link to comment Share on other sites More sharing options...
Ze Frias Posted May 27, 2014 Report Share Posted May 27, 2014 Fury shall report back, here, if new developments warrant. Thanks! Please do! Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted May 30, 2014 Report Share Posted May 30, 2014 SBT TC> Dragon no probs. philp Quote Link to comment Share on other sites More sharing options...
Eric Lau Posted June 8, 2014 Report Share Posted June 8, 2014 Last night, I cannot jam TC with 24F into two RED Dragon, only one EPIC's TC work. Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted June 9, 2014 Report Share Posted June 9, 2014 When you say you can't sync, what do you mean? That the camera doesn't see the TC at all? That you can't get TC, SYNC and GEN to all go green? philp Quote Link to comment Share on other sites More sharing options...
Eric Lau Posted June 9, 2014 Report Share Posted June 9, 2014 RED Dragon cannot read TC from my Zaxcom ERX2TCD in 24fps. Quote Link to comment Share on other sites More sharing options...
