mrkva Posted June 10, 2014 Report Share Posted June 10, 2014 Hello, has anyone here tried to put their own coiled cable into a rycote boompole without one? The construction seems almost the same. I only need the cable and cut the hole in the bottom. Also - any tips on sourcing coiled cable? Thanks, Jonas Quote Link to comment Share on other sites More sharing options...
Vincent R. Posted June 10, 2014 Report Share Posted June 10, 2014 Rycote sells these kits Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted June 10, 2014 Report Share Posted June 10, 2014 You can purchase coiled cables from any of the "usual suspects" (professional audio dealers) that support our industry. Quote Link to comment Share on other sites More sharing options...
studiomprd Posted June 10, 2014 Report Share Posted June 10, 2014 Hi, and welcome, MrKVA: " has anyone here tried to put their own coiled cable into a rycote boompole without one? "... well, yes. Quote Link to comment Share on other sites More sharing options...
mrkva Posted June 10, 2014 Author Report Share Posted June 10, 2014 Hi, and welcome, MrKVA: " has anyone here tried to put their own coiled cable into a rycote boompole without one? "... well, yes. And how did it go? Which coiled cable have you used? Quote Link to comment Share on other sites More sharing options...
studiomprd Posted June 11, 2014 Report Share Posted June 11, 2014 mrkva: " And how did it go? Which coiled cable have you used? " generally fine, and several various sources... what you have to watch out for is the coils building up an inductance flux field. too many turns, and your resonant field will collapse, and this tends to happen more often as the pole is extended.. Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted June 11, 2014 Report Share Posted June 11, 2014 I use a controlled array of anti resonant beads and the problem never arises. If the people being boomed sing close harmony in the key of E, however, the spontaneous sympathetic vibrations can cause all havoc to break loose. Also, an energetic enigmatic fiddle player may have the same effect, so you have to be careful to avoid "violins in the street." Quote Link to comment Share on other sites More sharing options...
drewski9 Posted December 18, 2014 Report Share Posted December 18, 2014 How do you handle the stray enigmatic RF spray caused by the anti resonant bead array. (unless you are using the new anti-rf titanium-halide coated beads) Quote Link to comment Share on other sites More sharing options...
