airport70 Posted July 18, 2014 Report Share Posted July 18, 2014 Since upgrading to the latest firmware my QRX receivers occasionally give warnings which I can't find any reference to, the QRX 200s flash VCO = 0.770 and the QRX100s flash VCO = 0.8, I read on the Zaxcom forums that the second warning might be a chip fault and might require going back to the mothership, but surely, unless I'm extreme unlucky and lighting has struck 6 times, there's another reason for this. Has anyone else had this issue and can spread any light? The actual performance of the receivers are satisfactory Quote Link to comment Share on other sites More sharing options...
Wandering Ear Posted July 18, 2014 Report Share Posted July 18, 2014 I had to send my qrx in for repair when I had that warning. Although it did work fine. Howy added a menu option to disable the warning if you decide to keep using it. There is potential for dropouts to be longer than they should be. Quote Link to comment Share on other sites More sharing options...
Cloud Wang Posted July 18, 2014 Report Share Posted July 18, 2014 yes you need send those units back in. Quote Link to comment Share on other sites More sharing options...
studiomprd Posted July 18, 2014 Report Share Posted July 18, 2014 (edited) airport: " I read on the Zaxcom forums that the second warning might be a chip fault and might require going back to the mothership, but surely, unless I'm extreme unlucky and lighting has struck 6 times, there's another reason for this. " why? (and don't call me Shirley) and: " Has anyone else had this issue and can spread any light? " yes: it indicates a possible chip fault, or an internal adjustment out of spec, neither user serviceable Edited July 18, 2014 by studiomprd Quote Link to comment Share on other sites More sharing options...
glenn Posted July 18, 2014 Report Share Posted July 18, 2014 This sounds like a simple calibration adjustment that our dealer in the UK can do. It does not need to come back to us. The unit will work fine like this. It is only a warning that the adjustment should be made. Glenn Quote Link to comment Share on other sites More sharing options...
