RadoStefanov Posted July 26, 2014 Report Share Posted July 26, 2014 Great News. I just spoke with Glenn and it turns out the qrx200 antenna connection can be easily rerouted to the bottom of the unit for people who use antenna distribution. That will allow for better cable management and cleaner front/top for great button access. The qrx200 already has 2 holes for IFB TC and Audio so it should be very easy to install the sma. Moving the qrx200 antenna sma to the bottom will allow me to make a One Unit Nomad, 4 qrx200s and a micplexer with common front panel. Quote Link to comment Share on other sites More sharing options...
fieldmixer Posted July 26, 2014 Report Share Posted July 26, 2014 That's pretty cool. Baby steps to the perfect bag. Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted July 26, 2014 Report Share Posted July 26, 2014 so you would leave the SMAs on the top? Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted July 26, 2014 Author Report Share Posted July 26, 2014 so you would leave the SMAs on the top? No. I would not. No need for sma on top... Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted July 26, 2014 Report Share Posted July 26, 2014 And what will you do about the holes where the top sma were? Quote Link to comment Share on other sites More sharing options...
soundtrane Posted July 26, 2014 Report Share Posted July 26, 2014 gaff? Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted July 26, 2014 Author Report Share Posted July 26, 2014 And what will you do about the holes where the top sma were? Will use the same plastic caps that are filling qrx200 unused zaxnet SMA antenna, TC In/Out and Audio In/Out wholes. Or will come up with a solution. Filling the wholes is the least of my challenges... Quote Link to comment Share on other sites More sharing options...
Derek H Posted July 26, 2014 Report Share Posted July 26, 2014 And what about when the day comes when you want to use the receiver in a different setup and you need the whips again? Quote Link to comment Share on other sites More sharing options...
johnpaul215 Posted July 26, 2014 Report Share Posted July 26, 2014 Zaxcom probably has the right caps. Offhand, the QRX100 without the QIFB has the unused ports capped. Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted July 26, 2014 Author Report Share Posted July 26, 2014 Zaxcom probably has the right caps. Offhand, the QRX100 without the QIFB has the unused ports capped. Just to clarify: this is only possible with the new qrx200. qrx100 can not be modded. Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted July 26, 2014 Author Report Share Posted July 26, 2014 And what about when the day comes when you want to use the receiver in a different setup and you need the whips again? I don't have a setup with whips. Once you go remote antenna with zaxcom you never come back. My qrx235s however will be left whips for when I use them for hops. Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted August 4, 2014 Author Report Share Posted August 4, 2014 And what will you do about the holes where the top sma were? So I am going to leave the top sma since they are soldered in th screen pcb. And if I want to use top whips , I can just reconnect them inside the qrx200 Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted August 7, 2014 Author Report Share Posted August 7, 2014 MOD IS DONE! Quote Link to comment Share on other sites More sharing options...
Olle Sjostrom Posted August 7, 2014 Report Share Posted August 7, 2014 The Zaxmobile! Nice Quote Link to comment Share on other sites More sharing options...
Matt Martin Posted August 7, 2014 Report Share Posted August 7, 2014 Amazing work Quote Link to comment Share on other sites More sharing options...
osa Posted August 7, 2014 Report Share Posted August 7, 2014 WOW that is inspiring! Ken Quote Link to comment Share on other sites More sharing options...
Derek H Posted August 7, 2014 Report Share Posted August 7, 2014 Slick! Seems like it was a pretty easy job? Did zaxcom endorse this mod? Please post your test results when available. Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted August 7, 2014 Author Report Share Posted August 7, 2014 Slick! Seems like it was a pretty easy job? Did zaxcom endorse this mod? Please post your test results when available. I doubt that zaxcom will endorse people drilling in to their gear. If you don't have to drill the mod is pretty easy. At best zaxcom can start selling the prepunched plates with cables. And call it "RADO MOD". haha Quote Link to comment Share on other sites More sharing options...
ao Posted August 10, 2014 Report Share Posted August 10, 2014 I doubt that zaxcom will endorse people drilling in to their gear. If you don't have to drill the mod is pretty easy. At best zaxcom can start selling the prepunched plates with cables. And call it "RADO MOD". haha nicely done! I hadn't taken the time to look inside my qrx200. was somewhat disappointed that the evolution to the 200 series did not include a multi pin connector. Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted August 10, 2014 Report Share Posted August 10, 2014 I doubt that zaxcom will endorse people drilling in to their gear. If you don't have to drill the mod is pretty easy. At best zaxcom can start selling the prepunched plates with cables. And call it "RADO MOD". haha you can probably just buy a panel for the 235 - it has the holes for the TC and IFB audio that you can utilize Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted August 11, 2014 Author Report Share Posted August 11, 2014 you can probably just buy a panel for the 235 - it has the holes for the TC and IFB audio that you can utilize That was my original idea but I could not wait... Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted September 7, 2014 Author Report Share Posted September 7, 2014 It is catching up... LA mixer did the "Rado's Mod" at Audio Department. Quote Link to comment Share on other sites More sharing options...
cory Posted September 9, 2014 Report Share Posted September 9, 2014 Nice, dude! Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted September 9, 2014 Author Report Share Posted September 9, 2014 My 3 wireless holder for nomad design is almost complete. It should be done by the end of the month. Quote Link to comment Share on other sites More sharing options...
