Soundequip Posted August 7, 2014 Report Share Posted August 7, 2014 Hi all Does anyone have a wiring diagram for a Tram TR-50 to Lectrosonics TA5F. It's the SM-series wiring that's backward-compatible to UM I'm after to assist a colleague. Thank you Soundequip Quote Link to comment Share on other sites More sharing options...
Peter Wong Posted August 7, 2014 Report Share Posted August 7, 2014 Check the Lectrosonics website servo bias wiring. Frequently asked questions #70. Hope that helps Peter Quote Link to comment Share on other sites More sharing options...
NathanWBS Posted August 7, 2014 Report Share Posted August 7, 2014 Here is a link to the PDF maual download of an SMB transmitter: http://ftp.lectrosonics.com/europe/smb-manual Once you download it, go to page 13. Hope it helps. Quote Link to comment Share on other sites More sharing options...
Soundequip Posted August 7, 2014 Author Report Share Posted August 7, 2014 Hi Peter and Nathan Thanks for the info. The Tram TR-50 AFAIK may be neg-biased as I found in a user manual online they seem to have been produced both ways. It doesn't want to work with the standard pos-biased wiring in the SMB user manual. Have we blown its mind? If not, how should we wire it? Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted August 7, 2014 Report Share Posted August 7, 2014 Hi Peter and Nathan Thanks for the info. The Tram TR-50 AFAIK may be neg-biased as I found in a user manual online they seem to have been produced both ways. It doesn't want to work with the standard pos-biased wiring in the SMB user manual. Have we blown its mind? If not, how should we wire it? For a negative bias Tram to a TA5 the ground goes to pin 3 and the positive goes to pin 1. Jump pins 2 & 4. No connection to pin 5 as that's for a line level input. There should be a minus sign (-) marking on the capsule body indicating negative bias. Eric Quote Link to comment Share on other sites More sharing options...
Soundequip Posted August 8, 2014 Author Report Share Posted August 8, 2014 Thank you very much Eric, Peter and Nathan. We'll give Eric's advice a go. Soundequip Quote Link to comment Share on other sites More sharing options...
