fatfatjames Posted July 29, 2008 Report Share Posted July 29, 2008 Hi i am planning to make some ta3m to xlr 3 pin cables for the red... I heard there is some kind of resistor in them does anyone know the value of the resistor and from which pin to which pin? Quote Link to comment Share on other sites More sharing options...
Rob Lewis Posted July 29, 2008 Report Share Posted July 29, 2008 http://www.sounddevices.com/notes/cameras/red-one/ This is the only info I know of, but I have all Sound Devices mixers so I follow their recommendations. Quote Link to comment Share on other sites More sharing options...
fatfatjames Posted August 3, 2008 Author Report Share Posted August 3, 2008 thanks... Quote Link to comment Share on other sites More sharing options...
RPSharman Posted August 3, 2008 Report Share Posted August 3, 2008 The Red should come with these cables as part of the package. I suppose it doesn't hurt to have your own, but you shouldn't have to. Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted August 3, 2008 Report Share Posted August 3, 2008 I like having a "Red fan" for my video audio snake--it eliminates having heavy XLR connectors hanging off the relatively fragile TA3Fs, and the camera doesn't really have a good place to strain-relief to. It also makes the connector side of the camera a little less cluttered. I use the PSC style snakes, and they made me a "Red fan" that works with them. Philip Perkins Quote Link to comment Share on other sites More sharing options...
pshap Posted August 14, 2008 Report Share Posted August 14, 2008 While mixing into the Red One camera, I once used the female XLR to male TA3 connector cables that are supplied with the Red One camera. When using the supplied cables, strain relief was necessary and that created a problem. The Red One has enough issues on it's own for me, an audio mixer, to be adding to them so I decided to use the Fan type breakaway harness cable that can be used with my PSC breakaway harness cable. The main difference that the breakaway harness cable has is a male TA5 that plugs into the Audio out on the Red One camera. This frees up the 1/8 mini audio out on the Red One for headphones or anything else you want to stab in there.... Pshap Quote Link to comment Share on other sites More sharing options...
fatfatjames Posted August 15, 2008 Author Report Share Posted August 15, 2008 Heard there is going to be a hardware upgrade for the red camera on the audio section... Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted August 15, 2008 Report Share Posted August 15, 2008 Yes, all the existing Reds are going back to Redville (shipping paid!) for an audio fix (about time) and a lens-support pin replacement. It will be interesting to see what they do, since they have gotten so much bad press about the audio on their camera. Philip Perkins Quote Link to comment Share on other sites More sharing options...
fatfatjames Posted August 15, 2008 Author Report Share Posted August 15, 2008 yap and i heard the cable no longer need resistor... and the 5k red is with full XLR but do not know is you can adjust the line input... Quote Link to comment Share on other sites More sharing options...
