pampasound Posted September 17, 2014 Report Share Posted September 17, 2014 I am about to purchase one but before wanted to know if anyone has tried the small size with an MKH416 (maybe with a right angled XLR?). I know that Rycote suggests the medium size for the 416 but i also know that they suggest the modular kit 4 but most people i know use a 416 on a modular kit 3. So, anyone out there with the super-shield small that can confirm if the 416 will fit? Thanks in advance! p.s: senator, i know the "contact the manufactures", and i did Quote Link to comment Share on other sites More sharing options...
studiomprd Posted September 17, 2014 Report Share Posted September 17, 2014 pam: " i know the "contact the manufactures", " contact the usual suspect you prefer, that's what they are there for... Quote Link to comment Share on other sites More sharing options...
Christopher Mills Posted September 18, 2014 Report Share Posted September 18, 2014 I'll give you a break here.. You definitely want the medium for a 416... from the man who owns one.. and has the other 2 sizes on hand with other mics to compare.. Quote Link to comment Share on other sites More sharing options...
pampasound Posted September 18, 2014 Author Report Share Posted September 18, 2014 @ Christopher...Thanks for the quick response! and I will definitely take your advice. But just curious to know since the 416 is 250mm, same as body length of the small kit, plus there is 100mm extra (50mm on front and 50mm on the back). I am wondering even with a right angled XLR you still think the 416 won't fit?... Thanks and please know that i appreciate your input. The reason i ask is because unfortunately i don't have a store to go to in my city to try for myself. Quote Link to comment Share on other sites More sharing options...
fieldmixer Posted September 18, 2014 Report Share Posted September 18, 2014 pam: " i know the "contact the manufactures", " contact the usual suspect you prefer, that's what they are there for... As great and well informed as our "usual suspects" can be, there are many things they might not particularly know. They aren't all working sound mixers after all, messing and futzing with every last detail and doodad of a custom built sound kit or cart. Also, calling in and taking the time to explain, and for them to attempt to find out a precise answer to an often very precise question, is often time consuming, costly, and inefficient. and likely taking them away from their primary responsibility of staffing the sales, service and rental departments. Contact usual suspect should not be blanket advice any longer. I'd further add, that many employees of the "usual suspects" read this board and likely have an active open page on a daily basis. So in effect, I would argue posting here would be considered "contacting the usual suspects". Albeit indirectly. Quote Link to comment Share on other sites More sharing options...
soundtrane Posted September 18, 2014 Report Share Posted September 18, 2014 air volume inside the windshield especially in the front is important. reducing it may have adverse effects on the performance of the windshield. just saying... Quote Link to comment Share on other sites More sharing options...
studiomprd Posted September 20, 2014 Report Share Posted September 20, 2014 field: " and likely taking them away from their primary responsibility of staffing the sales, service and rental departments. " please tie that steer up somewhere else.... taking care of our CS needs is a huge part of their jobs.... Quote Link to comment Share on other sites More sharing options...
Christopher Mills Posted September 22, 2014 Report Share Posted September 22, 2014 @ Christopher...Thanks for the quick response! and I will definitely take your advice. But just curious to know since the 416 is 250mm, same as body length of the small kit, plus there is 100mm extra (50mm on front and 50mm on the back). I am wondering even with a right angled XLR you still think the 416 won't fit?... Thanks and please know that i appreciate your input. The reason i ask is because unfortunately i don't have a store to go to in my city to try for myself. No, small supershield is not appropriate for a 416 even with the right angle XLR... the mic will bump into the inside of the shield as you cue it. I use the right angle xlr in the medium, and this gives me good but not generous room with a 416. Quote Link to comment Share on other sites More sharing options...
pampasound Posted September 22, 2014 Author Report Share Posted September 22, 2014 Thanks Chris!...I just got a medium size a couple of days ago. I'm really happy with it, even though is not as compact as I would like. Great product at a great price, I highly recommend it. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Travis Williamson Posted September 23, 2014 Report Share Posted September 23, 2014 Does anybody use the WS 295 with a 416? As seen here http://www.rycote.com/products/modular-windshield-ws-295-kit/ They say to add an extra 50mm for the connector, which brings the total length to 300mm, and the body length of the cage comes to 295mm. By those numbers it's a no brainer, however, the listing says that many favour it as an alternative to the WS 4. Personal experience with the WS 295 and a 416, anyone? Quote Link to comment Share on other sites More sharing options...
pkautzsch Posted September 23, 2014 Report Share Posted September 23, 2014 You can cut the last bit of the connector, or use a shortened (DIY or Kortwich) right angle. However, having a bit more space makes it safer with quick swings. Quote Link to comment Share on other sites More sharing options...
Travis Williamson Posted September 23, 2014 Report Share Posted September 23, 2014 Thanks Peter, that was pretty much the only option I could think of, though it may get tricky with the conbox built in. Quote Link to comment Share on other sites More sharing options...
Oscar Posted October 5, 2016 Report Share Posted October 5, 2016 Did you see the new "416" windshield? http://mymic.rycote.com/products/windshield-kit-416/ I was wondering if there's more difference then have the nice, even "rf shielded" right-angle xlr connector and some colour difference compared to a WS3-Kit... Anyone knows about it? Quote Link to comment Share on other sites More sharing options...
Marc Wielage Posted October 6, 2016 Report Share Posted October 6, 2016 I would contact Rycote and ask them: Rycote Microphone Windshields Ltd. Libby’s Drive - Slad Road Stroud, Gloucestershire, GL5 1RN GREAT BRITAIN +44 (0) 1453 759338http://www.rycote.com/ email: info@rycote.com Quote Link to comment Share on other sites More sharing options...
soundtrane Posted October 6, 2016 Report Share Posted October 6, 2016 better still: Simon Davies <simon@rycote.com> Quote Link to comment Share on other sites More sharing options...
Malcolm Davies Amps CAS Posted October 6, 2016 Report Share Posted October 6, 2016 On 23 September 2014 at 0:35 PM, Travis Williamson said: Does anybody use the WS 295 with a 416? As seen here http://www.rycote.com/products/modular-windshield-ws-295-kit/ They say to add an extra 50mm for the connector, which brings the total length to 300mm, and the body length of the cage comes to 295mm. By those numbers it's a no brainer, however, the listing says that many favour it as an alternative to the WS 4. Personal experience with the WS 295 and a 416, anyone? Yes I do Travis. Quote Link to comment Share on other sites More sharing options...
