Dennis Kersten Posted September 19, 2014 Report Share Posted September 19, 2014 So I'm using the 10 pin output A to send my audio left/right to camera. Camera receives left/right but return A on the 664 gives me right/left audio... What am I doing wrong? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Christopher Mills Posted September 19, 2014 Report Share Posted September 19, 2014 got your headphones on backwards? Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted September 19, 2014 Report Share Posted September 19, 2014 So I'm using the 10 pin output A to send my audio left/right to camera. Camera receives left/right but return A on the 664 gives me right/left audio... What am I doing wrong? Sent from my iPhone using Tapatalk Your breakout cable is wired for the PSC way of wiring not the Sound Devices protocol. The HP returns are reversed in the PSC cable. To fix the problem you need to reverse the leads on pins 5 & 7 of the 10 pin Hirose connector after you've removed the set screw with a.050 allen wrench and unscrewed the threaded insert pin block, then find pins 5 & 7 and put it all back together after burning your fingers with the soldering iron and checking that there are no shorts left between the pins. By this time you've lost the .050 set screw..(yes you will) and you just can't buy one at Home Depot and you'll be pissed that you even tried to DIY. Of course you could just turn your headphones around and all will be well. Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted September 20, 2014 Report Share Posted September 20, 2014 I have a lot of PSC snakes, some pretty old, and haven't had this issue with 664. Maybe your snake was miswired? Are you sure all the pieces of your snake are wired the same way? When you got yr snake did you ask for the 664 version? philp Quote Link to comment Share on other sites More sharing options...
Dennis Kersten Posted September 20, 2014 Author Report Share Posted September 20, 2014 Thanks all! It's my "old" snake I use with my Cooper 104. A new snake is allready in the make for output/return B/C which will be 664 style. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
TomBoisseau Posted September 20, 2014 Report Share Posted September 20, 2014 I have a three 10p Hirose' to Neutrix snakes wired for the PSC standard and they work correctly on both of my 664's. Tom Quote Link to comment Share on other sites More sharing options...
Matt Mayer Posted September 20, 2014 Report Share Posted September 20, 2014 The problem most likely isn't the 10pin connector wiring but the snake wiring itself. It's not clear if you are using an Engh-style XLR7 breakaway or PSC/Remote Audio Neutricon breakaway. Be aware that PSC and Remote have diffent wiring schemes for the Neutricon. If you mix and match camera/mixer ends, you can have issues with flipped phase on the sends and returns. Quote Link to comment Share on other sites More sharing options...
bralleput Posted September 20, 2014 Report Share Posted September 20, 2014 Your breakout cable is wired for the PSC way of wiring not the Sound Devices protocol. The HP returns are reversed in the PSC cable. To fix the problem you need to reverse the leads on pins 5 & 7 of the 10 pin Hirose connector after you've removed the set screw with a.050 allen wrench and unscrewed the threaded insert pin block, then find pins 5 & 7 and put it all back together after burning your fingers with the soldering iron and checking that there are no shorts left between the pins. By this time you've lost the .050 set screw..(yes you will) and you just can't buy one at Home Depot and you'll be pissed that you even tried to DIY. Of course you could just turn your headphones around and all will be well. Eric!This one is really funny!!!!Hahahahaha. Quote Link to comment Share on other sites More sharing options...
