osa Posted October 3, 2014 Report Share Posted October 3, 2014 I repaired a power cable with a busted 4 pin XLR cable for a friend of mine. It was made from Canare L-4E5C. Both blues to pin 1 and both whites to pin 4. all shielding stripped back at the connector. First time I've ever seen Canare cable like that used for power applications but I've never paid much attention to power connections. Is L-4E5C cable commonly used and/or suitable for DC power cabling? All DC Cables I have repaired were single cable 2 conductor red/white no shield cables. Curious to know if thinner cables like redco TGS-1 or Mogami W2697 can be used for lightweight DC connection applications? Ken Quote Link to comment Share on other sites More sharing options...
studiomprd Posted October 3, 2014 Report Share Posted October 3, 2014 osa: " Curious to know if thinner cables " current may be an issue... Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted October 3, 2014 Report Share Posted October 3, 2014 I repaired a power cable with a busted 4 pin XLR cable for a friend of mine. It was made from Canare L-4E5C. Both blues to pin 1 and both whites to pin 4. all shielding stripped back at the connector. First time I've ever seen Canare cable like that used for power applications but I've never paid much attention to power connections. Is L-4E5C cable commonly used and/or suitable for DC power cabling? All DC Cables I have repaired were single cable 2 conductor red/white no shield cables. Curious to know if thinner cables like redco TGS-1 or Mogami W2697 can be used for lightweight DC connection applications? Ken The Canare star quad will be fine for 12vdc feeds. I would hesitate to use the TGS-1. 18 or 22 gauge zip cord does the job very well also with 12vdc feeds. Quote Link to comment Share on other sites More sharing options...
jrd456 Posted October 3, 2014 Report Share Posted October 3, 2014 I use 18AWG---better safe than sorry Quote Link to comment Share on other sites More sharing options...
RPSharman Posted October 3, 2014 Report Share Posted October 3, 2014 It's very unwise to use shielded cable, as it is more likely to short if damaged. High quality speaker wire or lamp wire is better, and cheaper, and easier to solder for people like me. Quote Link to comment Share on other sites More sharing options...
CraigF Posted October 4, 2014 Report Share Posted October 4, 2014 if we're talking long runs with 4 pin XLRs on both ends; 18/3 SOOW conneting green coinducter to the shell on both ends Quote Link to comment Share on other sites More sharing options...
soundtrane Posted October 4, 2014 Report Share Posted October 4, 2014 thinner the cable more the resistance... edited... heh. Quote Link to comment Share on other sites More sharing options...
Boomboom Posted October 4, 2014 Report Share Posted October 4, 2014 ...! Quote Link to comment Share on other sites More sharing options...
RPSharman Posted October 4, 2014 Report Share Posted October 4, 2014 thicker the cable more the resistance... I think you might have that backwards. Quote Link to comment Share on other sites More sharing options...
Matthias Richter Posted October 4, 2014 Report Share Posted October 4, 2014 no "might" here. Quote Link to comment Share on other sites More sharing options...
studiomprd Posted October 4, 2014 Report Share Posted October 4, 2014 vin: " thinner the cable more the resistance..." ...and the greater the voltage drop Quote Link to comment Share on other sites More sharing options...
Derek H Posted October 4, 2014 Report Share Posted October 4, 2014 I've used Canare Mic cable for dc power cables. Usually when Hirose 4-pin connectors are involved. The advantage is the conductors actually fit in the solder cups (larger gauge won't) and the outer diameter of the overall cable is a good match for the strain relief system in those connectors. Otherwise you have to pile on shrink tubing to zip cord which can be a mess and is hard to get just right. Quote Link to comment Share on other sites More sharing options...
RPSharman Posted October 4, 2014 Report Share Posted October 4, 2014 I've used Canare Mic cable for dc power cables. Usually when Hirose 4-pin connectors are involved. The advantage is the conductors actually fit in the solder cups (larger gauge won't) and the outer diameter of the overall cable is a good match for the strain relief system in those connectors. Otherwise you have to pile on shrink tubing to zip cord which can be a mess and is hard to get just right. I can see your point, but Hirose connectors are usually used in a bag, which is an environment with a lot of quishing of things into little spaces. I'd be worried about shorts. But if it has worked for you so far... Quote Link to comment Share on other sites More sharing options...
