Eric Toline Posted August 8, 2008 Report Share Posted August 8, 2008 Posting for a friend. 744t set at 29.97, SB1 set at 29ndf. Major drift after a few minutes. Operator error or other causes?? Eric Quote Link to comment Share on other sites More sharing options...
RPSharman Posted August 8, 2008 Report Share Posted August 8, 2008 Both of these products hold time code extremely well, provided the SB1 has paid a visit to Denecke in the last year or two. I would double check your friend is sure that both machines are set for ND. If settings are correct, time to send in the SB1 for an update. Robert Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted August 8, 2008 Report Share Posted August 8, 2008 Posting for a friend. 744t set at 29.97, SB1 set at 29ndf. Major drift after a few minutes. Operator error or other causes?? Eric Verify 744T is really on NDF? SB1 is pretty old, so it may have a problem? Easy to set SB1 to wrong frame rate--really have to look closely to see if the switch really is on the FR you want. Philip Perkin s Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted August 8, 2008 Author Report Share Posted August 8, 2008 Verify 744T is really on NDF? SB1 is pretty old, so it may have a problem? Easy to set SB1 to wrong frame rate--really have to look closely to see if the switch really is on the FR you want. Philip Perkin s Word from the set is that all is well now. He says it must have been op error. SB1 and slate had come back from complete overhaul at Denecke about 2 months ago. Eric Quote Link to comment Share on other sites More sharing options...
