Matthias Richter Posted December 8, 2014 Report Share Posted December 8, 2014 normaly when using remix with my Zaxnet setup all TRXs play in sync together. Every now and then it happens that they are out of sync and I will get double sounds / echo. Had actors in a basement doing a scene where I had some minor drop outs. Wanted to remix but 3 out of 5 takes had a TRX being off by nearly 1sec. How long is a TRX holding stable TC without significant drift when NOT receiving TC over Zaxnet? Thanks, Matthias Quote Link to comment Share on other sites More sharing options...
studiomprd Posted December 8, 2014 Report Share Posted December 8, 2014 MR: " How long is a TRX holding stable TC without significant drift when NOT receiving TC over Zaxnet? " based on the limited information you provided, I'm not sure you have even asked the correct question... you really ought to be discussing your situation with Zaxcom's 24/7 technical support. actually, I believe the question you posed has been answered here before, several times, plus in the spec's and manuals... Quote Link to comment Share on other sites More sharing options...
OneLouder Posted December 9, 2014 Report Share Posted December 9, 2014 I didn't think that remix/rerecord function was working. Are you on a Nomad? or Deva/Fusion? Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted December 9, 2014 Report Share Posted December 9, 2014 This feature has not been implemented, as promised, on the Nomad. With a Deva & Fusion it quit working for a while with some versions of transmitter firmware. In later versions, it has been restored, but I haven't checked it closely enough to know if drift like this is common or not. Quote Link to comment Share on other sites More sharing options...
vale Posted December 9, 2014 Report Share Posted December 9, 2014 I can confirm the feature has been recently recovered. There was a problem with the newer TRX firmwares that Howy solved with the last 898B version. I did some tests and on my Fusion it works as aspected now. As for the drift issue, I had it sometimes even when the feature worked before of the new firmware, but I'm not remembering which was the cause (though it was explained somewhere here or in the Zaxcom forum). Quote Link to comment Share on other sites More sharing options...
Matthias Richter Posted December 9, 2014 Author Report Share Posted December 9, 2014 working with a Fusion here. The remix works fine most of the time. On that day I had like take 1+3+5 being out of sync and 4+7 in tune. If it´s drift caused by the TRX not receiving TC for a while (talking 20min max I would say) I cannot rely on that feature. Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted December 9, 2014 Report Share Posted December 9, 2014 Matthias, is the drift consistent or variable? I had similar problem with one of my transmitter. At the end I believe the problem was upgrading a few firmwares without formatting the internal card... working with a Fusion here. The remix works fine most of the time. On that day I had like take 1+3+5 being out of sync and 4+7 in tune. If it´s drift caused by the TRX not receiving TC for a while (talking 20min max I would say) I cannot rely on that feature. Quote Link to comment Share on other sites More sharing options...
studiomprd Posted December 9, 2014 Report Share Posted December 9, 2014 RS: " is the drift consistent or variable? " or is it not really a drift, but a constant, an offset ?? Quote Link to comment Share on other sites More sharing options...
CRAIG Posted February 25, 2015 Report Share Posted February 25, 2015 I have had this issue and found the simplest way for me to deal with it was to download the files from the SD cards with Zaxconvert and make sure every thing is in sync on the computer where I can both see and hear everyting Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted February 25, 2015 Report Share Posted February 25, 2015 Mix and match TX to recorder can be problematic. Quote Link to comment Share on other sites More sharing options...
