emwoerks Posted December 14, 2014 Report Share Posted December 14, 2014 Has anyone had problems transferring audio files from the SD card or CF card? I had a bit of a problem playing back the final track recorded from my days work. I can play back the final track on my 633 but was unable to download onto an external hard drive. Info showed the bits, but no duration............ Quote Link to comment Share on other sites More sharing options...
Matt Mayer Posted December 15, 2014 Report Share Posted December 15, 2014 Most likely a card error. Did you pull the card at the end of the day immediately after recording? Quote Link to comment Share on other sites More sharing options...
emwoerks Posted December 15, 2014 Author Report Share Posted December 15, 2014 Nope. All the rest of the files were good. As a matter of fact I opened up the file on WAVE AGENT and everything was there, tracks, info, all the info. Continued shooting today on the same cards and no problems. The person handling the median had no problem playing back on Adobe Premier, FCP 7, VLC, and Quicktime 7. Problem playing back on Quicktime 10. Quote Link to comment Share on other sites More sharing options...
Matt Mayer Posted December 15, 2014 Report Share Posted December 15, 2014 So did it turn out the file wasn't a problem, it just wouldn't play back in QT10? Quote Link to comment Share on other sites More sharing options...
Randy Freeman Posted December 16, 2014 Report Share Posted December 16, 2014 With mine it seeems to be a bit more picky about the cf than the sd media. I was doing 2nd unit work and had an inadequate cf card and it got weird. The machine wouldn't do anything. Couldn't even shut it off. The master reboot was the solution to regain control. The cf card was the culprit. Changed to an approved card and haven't had any further issues. I did pull out the 702T for the day since it was a non dialog kinda day. The 702T is much more forgiving in its cf requirements. I did have go to wave agent to do sound reports for the day. I recently went to the Trew Audio opening in Atlanta and found an issue brought up by other mixers. It seems that X1 & X2 track assingments were changing when the machine was powered off. Still had the blinking blue light but the previous assingments seemed to change when powered off and on. Not a big issue, but I do always check my X1,X2 assingments now every time I turn it on. Back to piont with approved media I haven't had any trouble transferring from either sd or cf. Quote Link to comment Share on other sites More sharing options...
Stillweii Posted January 30, 2015 Report Share Posted January 30, 2015 Had this same issue when recording ISOS to it. Will not work on new macs...but the minute I put it in my Macbook first Generation it works. Using: Vivitar 50 in 1 card reader Not sure of what CF I use, but I know its approved last time I checked. Quote Link to comment Share on other sites More sharing options...
