Vincent R. Posted December 28, 2014 Report Share Posted December 28, 2014 Always thought it was the cable connection, trying to reinsert it solves it for a while, but the actual problem is inside the cup: http://youtu.be/WRXYgfIkX18 Quote Link to comment Share on other sites More sharing options...
soundtrane Posted December 28, 2014 Report Share Posted December 28, 2014 it's an inelegant design - or a design that did not take into consideration heavy outdoor use, physical and environmental bashing, etc. the reason people change the cable (first) is because it is FAR expensive to change the FEMALE part which is embedded in the cup which also houses the transducer and therefore is the price to pay. obviously the cable change does not alleviate the issue. i gave up on trying to 'tweak' the 'FEMALE' part of the connector system in the HD25-i II ... Quote Link to comment Share on other sites More sharing options...
Olle Sjostrom Posted December 28, 2014 Report Share Posted December 28, 2014 The HD26 is fine. Sound exactly the same, a bit more comfy and a little more isolation ime. But my hd25s have been run over by a car and the only thing I need to do once in a while is to nudge the cable a bit.. Quote Link to comment Share on other sites More sharing options...
pindrop Posted December 29, 2014 Report Share Posted December 29, 2014 The HD26 is fine. Sound exactly the same, a bit more comfy and a little more isolation ime. But my hd25s have been run over by a car and the only thing I need to do once in a while is to nudge the cable a bit.. Sorry don't agree, I don't think the HD26's sound as good, they are less precise, and no more comfy but heavier, more difficult to put on with one hand, and the HD25 'nudge the cable a bit' will always happen at a very inconvenient time. It's a great shame as the HD25's are the best for the combination of good sound and ergonomics, that is apart from, the one serious unsolvable design flaw - the dammed intermittent connection. I had to stop using them after years of struggling with intermittent connections (I've got 4 pairs) because I couldn't stand it any more. I use HD26's now, but they're not as good. imho. Quote Link to comment Share on other sites More sharing options...
Johnny Karlsson Posted December 29, 2014 Report Share Posted December 29, 2014 Not too long ago, mine started to have this same issue. I opened them up to find those tiny little copper wires and just didn't feel like proceeding from there.... looked like breathing on them may break 'em. Quote Link to comment Share on other sites More sharing options...
VM Posted January 3, 2015 Report Share Posted January 3, 2015 Always thought it was the cable connection, trying to reinsert it solves it for a while, but the actual problem is inside the cup: http://youtu.be/WRXYgfIkX18 Vincent, Did you try this way to solve the intermittent connection ? It seems too simple ! Quote Link to comment Share on other sites More sharing options...
soundtrane Posted January 4, 2015 Report Share Posted January 4, 2015 i tried this and ended up breaking one of the wires coming in from the speaker element... end of story. Quote Link to comment Share on other sites More sharing options...
pindrop Posted January 4, 2015 Report Share Posted January 4, 2015 It might work for a while until the next time it stops working, which will be at the most inconvenient time! This is a design fault in professional headphones which Sennheiser have not addressed properly for many years. HD II's changed the blades from aluminum to gold plated but it did not stop the connection failing after a period of time of location use. One might have hoped that it would not have been beyond the wit of a fairly big German audio company like Sennheiser to have solved this, but apparently it is, despite having received complaints about it for maybe a decade or more! It's a real shame because in every other way these headphones are the best I've used, for location recording, but I had to finally give up using them. Quote Link to comment Share on other sites More sharing options...
Jaree Posted January 27, 2020 Report Share Posted January 27, 2020 Bought a new pair of hd25s. However, my old hd25 Light, the cable started having problems. Was thinking of changing them but I can’t seem to pull out the cable’s connectors. They’re in so tight I’m afraid I’d break them pulling them out. I’ve seen vids with ppl pulling the connections out with ease. I’ve tried using pliers but feared they’d break the connectors. Anyone have a resolution? Quote Link to comment Share on other sites More sharing options...
tourtelot Posted January 28, 2020 Report Share Posted January 28, 2020 Yep. Buy headphone that aren't so fussy. D. Quote Link to comment Share on other sites More sharing options...
Vincent R. Posted January 28, 2020 Author Report Share Posted January 28, 2020 3 hours ago, tourtelot said: Yep. Buy headphone that aren't so fussy. D. After about 15 years of struggle, I came to this conclusion. Life's too short. Quote Link to comment Share on other sites More sharing options...
