Robert Buncher Posted January 16, 2015 Report Share Posted January 16, 2015 I need to make a cable to send time code and audio from a TIG to a Blackmagic camera. So the BMC has two 1/4 inputs which are balanced. I want to send the TC to one channel and audio to the other channel. I'll be splitting these from the 1/8 connector. How would I wire this? Thanks, Bob Quote Link to comment Share on other sites More sharing options...
Boomboom Posted January 16, 2015 Report Share Posted January 16, 2015 On the Tig side it's: Tip-time code Sleeve-ground If you want to use the audio pass-thru function, audio signal is on the Ring pin. I don't have the BM pinout but you can complete the equation when you get it. Quote Link to comment Share on other sites More sharing options...
Robert Buncher Posted January 16, 2015 Author Report Share Posted January 16, 2015 Thanks Pierre, My concern was sending an unbalanced signal into a balanced input. Up until now I had been sending just an audio signal from a G2 to the BMC. I would jump the shield and ring on the G2 1/8 and connect them to the shield on the BMC 1/4 and then connect the G2 tip to the BMC tip. This works fine. It seems my option with sending both TC and audio is possibly: TIG 1/8 to BMC 1/4 x2 Shield to Shield Left and Right Tip (TC) to Tip Left (TC) Ring (Audio) to Ring Right (Audio) I'll try this but I think there will be the problem of unbalance into balanced. Bob Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted January 16, 2015 Report Share Posted January 16, 2015 It will work fine. You're sending an unbalanced feed into an unbalanced connection. Basically it's just like a headphone connection with L & R audio and a common ground. Remember that TC is an audio signal. Quote Link to comment Share on other sites More sharing options...
Robert Buncher Posted January 16, 2015 Author Report Share Posted January 16, 2015 Thanks Eric. Bob Quote Link to comment Share on other sites More sharing options...
