DavidBerlin Posted January 18, 2015 Report Share Posted January 18, 2015 Hello everyone, I just got the PSC Sixpack and tried to install my Wisycom MCR42 receivers. For some reason the cables for the antenna distribution (Sma) on the top panel are too short. The receivers are fully inserted, but there is no way I can hook up the cables in a "criss-cross" pattern. Does anyone have the same problem? Quote Link to comment Share on other sites More sharing options...
chrisyking Posted January 19, 2015 Report Share Posted January 19, 2015 I think these units are designed to work with lectrosonics as well. Maybe you have the lectrosonics cable option? Quote Link to comment Share on other sites More sharing options...
Derek H Posted January 19, 2015 Report Share Posted January 19, 2015 You need to talk to Ron at PSC: ron@professionalsound.com Quote Link to comment Share on other sites More sharing options...
Matthew Sonnenfeld Posted January 19, 2015 Report Share Posted January 19, 2015 Also call Gotham Sound NY and ask to speak to Natalie. She 3D prints problem solvers like this. The issue is the little adapter gets in the way of the cables. Were there a 3D printed adapter that allowed for the cables, it would be fine. Quote Link to comment Share on other sites More sharing options...
Richard Thomas Posted January 20, 2015 Report Share Posted January 20, 2015 Raycom in the UK will modify the brackets so there's gaps the cables can go through if you specify you're using them with the six pack Quote Link to comment Share on other sites More sharing options...
Ze Frias Posted January 20, 2015 Report Share Posted January 20, 2015 Also call Gotham Sound NY and ask to speak to Natalie. She 3D prints problem solvers like this. The issue is the little adapter gets in the way of the cables. Were there a 3D printed adapter that allowed for the cables, it would be fine. Nathalie is a 3D printing wizard. She can help you make almost any trinket or thingamajig to fit your needs, and she recently did an adapter for a similar scenario: https://www.gothamsound.com/news/true-tales-audio-problems-solved-3d-printer Quote Link to comment Share on other sites More sharing options...
Richard Thomas Posted January 20, 2015 Report Share Posted January 20, 2015 Nathalie is a 3D printing wizard. She can help you make almost any trinket or thingamajig to fit your needs, and she recently did an adapter for a similar scenario: https://www.gothamsound.com/news/true-tales-audio-problems-solved-3d-printer Richard Meredith's made exactly the same part over here too Quote Link to comment Share on other sites More sharing options...
NLo Posted January 28, 2015 Report Share Posted January 28, 2015 Richard Meredith's made exactly the same part over here too Super cool! Was it identical or another version for the same problem? We shared the .stl file in the article so you can print yourself or make changes, I always like to see how other people solve these things. Quote Link to comment Share on other sites More sharing options...
Richard Thomas Posted January 28, 2015 Report Share Posted January 28, 2015 It's another version for the same problem. He's had a batch moulded, rather than 3D printed Quote Link to comment Share on other sites More sharing options...
