Soldering problems
berniebeaudry
Getting the good solder has made all the difference!  I also got one of those tip cleaners (looks like a brass dish scrubby) that doesn't decrease the tip temperature like the wet sponge.  I find that I can use a lower temp now and get faster/better results.  Nice work on the padded cable!
  • 1 year later...
Question for the solder brains: For what we do, is it prudent to use the little tub of flux?
It's Zinc Chloride and recommended for copper, but they mention other applications, like sweating copper fittings. EG: Mitee Soldering Paste is one. The other is Dutch Boy Tinning Flux. Another is an old Radio Shack Rosin Solder Paste. That one's in a tube, and recommended for electronics. All three of them have made the solder flow so nicely, I never questioned it. The Tinning Flux mentions "for use with any Lead-Free Solder". But I use 63/37, eh...which has Lead.
The joints I make are never less than pretty, shiny and succinct, but I wonder...
On 4/16/2015 at 10:10 AM, Todd Weaver said:
I like the sponge, it cleans nicely and prompts the iron to get its temp back up for its next slaughter joint.
Sponge (wet) is not recommended by experts. because of the thermal shock caused. brass wool is the recommended method for cleaning tips. and - AVOID tip tinners... also when you finish, clean the tip and 'tin' it with solder before you turn the thing off. this way the tip is always covered and will not oxidise...
After years of using cheap solder station(s), i finally invested in the industry standard - METCAL. What a difference! It is simply incredible... Of course, expensive, but...
I have the pre-heater, hot air station and the soldering station with two handpieces (soldering iron and tweezers) now...
-vin
I've heard both recommendations on wet sponges.
Weller (who is one of the respected brand names for solder stations over here) recommends using their sponges with distilled water. you could think they just want to make extra money, but since they are only 1.50 or so I don't think that's the main reason (they could also sell brass wool).
I have their entry level station and agree it's a big difference over a no-name iron (was affordable too, got it on a sale for 80EUR)
some other good tips here:
https://www.astro.umd.edu/~harris/docs/WellerSoldering.pdf
Thanks for such salient input guys. And Vin, the METCAL is darn impressive. Great advice on tinning the tip before power down. I've been wiping it off on the sponge, leaving it open to the local elements.
My daily driver is the WES51, but I've had to repair it and tweak it a few times. I took it apart yesterday seeking a faulty connection.
And besides help with tinning (the solder actually runs uphill by capillary action on the stranded stock), the flux in the tub makes a wonderful little bath for the tip. I melt a little pool of it, then sponge the tip shiny clean. It then drinks the Kester, and it's raring to go.
I've the right solder, I just wondered if the flux I use is proper, or perhaps corrosive...or if it matters (EG: Ammonium Chloride or Zinc Chloride?). It seems to collect any slag and leave it in the tub, because over the years, I noted that it gets darker and darker..sometimes I look closely and notice slag particulate in it. That's exactly where I want it. Not in my joints.
And +1 Sound Intuition.
