Richard Ragon Posted March 17, 2015 Report Share Posted March 17, 2015 I've got a small mystery. I pulled my cart out to do some testing. I've got a cart gig coming up next month. I've got a Yamaha 01v96 going to a Pix260i via Daunte. I hit the record, talk a bit into my slate mic, while listening.. Everything sounds great. Mix, Boom1, ISOs, all good. I move my headphone jack to the Pix260i, and listen to the recording.. ALL SOUNDS GREAT. I take the files, put them in Wave agent to listen... I have these weird static??? WTF?? That doesn't play back that way. The static is very random, even on the channel where I don't have a mic on?? So.. this is weird.. First guess it's the Pix260i, but it plays the files back perfect?? Can the media be corrupting every take?? Here's a sample..http://good4sound.com/downloads/Hotel/12-002.wav Any suggestions would be helpful. Thanks in advance. -Richard Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted March 17, 2015 Report Share Posted March 17, 2015 It sounds like it might be a clocking error of some sort. Quote Link to comment Share on other sites More sharing options...
Richard Ragon Posted March 17, 2015 Author Report Share Posted March 17, 2015 I thought that at first too.. But it plays back perfect?? Checked the Daunte control panel, and everything is green.. no errors on the Daunte logs. I can go though all of these again.. maybe something got 'off'. I thought about the media perhaps also.. The card is on the media list. It's a SanDisc 32G, Extreme Pro; UDMA7; 160MB/s. I haven't try pulling the media from the SSD, yet. Was going to try that next... How come I hear nothing while recording, or playback?? Weird! Quote Link to comment Share on other sites More sharing options...
soundpod Posted March 17, 2015 Report Share Posted March 17, 2015 Have you tried playing the files back on a different program to wave agent? Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted March 17, 2015 Report Share Posted March 17, 2015 Check everything on your system that might affect clocking -- pull up or pull down, frame rate, drop or non-drop time code, etc. I'm not sure on that system which of these even might affect timing, but they're all worth investigating at this point. Quote Link to comment Share on other sites More sharing options...
Chris Durfy Posted March 17, 2015 Report Share Posted March 17, 2015 I haven't had that issue with my 260i. I have had a couple of instances where the Pix didn't seem to latch onto Dante on bootup. Using approved media. Reboot solved the problem. Good luck with your issue Richard! Quote Link to comment Share on other sites More sharing options...
Richard Ragon Posted March 17, 2015 Author Report Share Posted March 17, 2015 Thanks all who posted, I'm still troubleshooting. My first choice is that the Pix has got to be writing bad files when it's 'finalizing'. I've learned that timing issues, simply cause the recorder not to get any tracks, or no inputs. I'm not leaving anything out though. I'll check the other media, and see if that is same. Whats so weird is that it plays back on the Pix, without any issues. Quote Link to comment Share on other sites More sharing options...
MRWsound Posted March 17, 2015 Report Share Posted March 17, 2015 Double checking because I haven't seen it mentioned yet, but on the Pix which playback source are you listening to? The CF card or the SSD? Have you listened to the files from the hard drive yet? You may have a corrupted card causing the issue when listening on your computer, but not on the SSD which may be your default playback source on the Pix. Quote Link to comment Share on other sites More sharing options...
Chris Durfy Posted March 17, 2015 Report Share Posted March 17, 2015 Good point MRW. Quote Link to comment Share on other sites More sharing options...
enginufuk Posted March 17, 2015 Report Share Posted March 17, 2015 Double checking because I haven't seen it mentioned yet, but on the Pix which playback source are you listening to? The CF card or the SSD? Have you listened to the files from the hard drive yet? You may have a corrupted card causing the issue when listening on your computer, but not on the SSD which may be your default playback source on the Pix. Yep. That might be it. Quote Link to comment Share on other sites More sharing options...
Richard Ragon Posted March 17, 2015 Author Report Share Posted March 17, 2015 Yep.. I pulled the SSD drive out, plugged it the FW800, and Guess what.. The Primary drive (SSD) seams to be unaffected. The primary drive is also the playback drive. So, the problem is now traced to the secondary drive (CF). So, it's either the Caddie, or the Media?? This is a weird one! Thanks everyone! Quote Link to comment Share on other sites More sharing options...
Richard Lightstone, CAS Posted March 17, 2015 Report Share Posted March 17, 2015 The Pix and 970 write the files at the same time. So if the files are on the SSD, then you have a corrupted CF card. How old is the card? They do wear out over time. I know you all like to blame DANTE, however this seems to be a media issue. If it records to the internal SSD, and it plays back, how is this related to DANTE?? Quote Link to comment Share on other sites More sharing options...
Mirror Posted March 17, 2015 Report Share Posted March 17, 2015 Who said it was the fault of Daunte? Quote Link to comment Share on other sites More sharing options...
old school Posted March 17, 2015 Report Share Posted March 17, 2015 Who said it was the fault of Daunte? Must be from a different thread. CrewC Quote Link to comment Share on other sites More sharing options...
Richard Ragon Posted March 18, 2015 Author Report Share Posted March 18, 2015 I don't remember anyone blaming Daunte.. However, if you have sync troubles, it's be my experience, that the whole thing shuts down. This was something completely different. However, I did take the time to fire up my Mac, start the Dante controller, and just look at the logs, sync errors, etc. RLS, The CF card is only 2 months old. I destroyed my last one.. Small hiccup, my bad. It wont recover.. Anyone want a free Extreme Pro 32G Sandisk? So, continue on my troubleshooting.. I formatted both SSD and CF this morning.. And the errors went away. Just to be on the safe side I stopped at Trew today, and picked up another brand of CF. I'm reasonably sure it was an odd thing with the CF card, and NOT the caddie. Thanks all. Quote Link to comment Share on other sites More sharing options...
old school Posted March 18, 2015 Report Share Posted March 18, 2015 Glad it all worked out R R but I have to say to all, 3 cards are a minimum to have in rotation in my opinion. CrewC Quote Link to comment Share on other sites More sharing options...
Todd Weaver Posted March 18, 2015 Report Share Posted March 18, 2015 Quote Link to comment Share on other sites More sharing options...
