chris_bollard Posted September 18, 2008 Report Share Posted September 18, 2008 Wanted to check in the wider world if anyone is experiencing this issue with their Zaxcom Stereoline transmitter. Occassionally when I power up the unit fails to power up - no little flashing LED - no signal transmitted. Turn the power off and on again (Hawkswoods adapter) and up it comes. I have spoken to friends and they report experiencing the same Any comments - Fixes? Thanks Chris B Quote Link to comment Share on other sites More sharing options...
Rob Lewis Posted September 18, 2008 Report Share Posted September 18, 2008 Chris, I have experienced the same thing with my stereoline TX. I happens with both the Hawks woods and the BDS system, but I don't know why. I just confirm visually that it fires up when I hit the switch so I don't get burned. Quote Link to comment Share on other sites More sharing options...
jason porter Posted September 18, 2008 Report Share Posted September 18, 2008 my transmitter was shorting out...my own fault. I opened the case and when I closed it again, the case was shorting on one of the circuit boards. (or the battery contacts) It would only happen when I clipped it to my bag (and put enough pressure on the case near the battery compartment, from the belt-clip) I added a little bit of insulation (electrical tape) on the inside of the case, and no problems since Quote Link to comment Share on other sites More sharing options...
