johnpaul215 Posted May 8, 2015 Report Share Posted May 8, 2015 You can always check the life with maha charger That probably makes a lot more sense than the date system. I'm sure my usage is kind of uneven, and some batteries probably just have better insulation and will therefore last longer. Quote Link to comment Share on other sites More sharing options...
Toy Robot Posted May 8, 2015 Report Share Posted May 8, 2015 Although I have not been disappointed with my older white Eneloops, I bought a 4-pack of the black Sanyo Eneloop Pros after reading people's great experiences. Tried them out in my SMQVs and immediately ordered 16 more. I'll be using these now exclusively in talent TX, with my white Eneloops now relegated to ERXs, slates and other AA purposes. Quote Link to comment Share on other sites More sharing options...
efksound Posted May 9, 2015 Report Share Posted May 9, 2015 Sorry for the small off topic, but what kind of rechargeables are you guys using with a TS-C slate ? With Eneloops, amazon, duracells, I have a hardtime inserting the battery sled in the compartment and it's impossible to get it out without using a tool. Quote Link to comment Share on other sites More sharing options...
al mcguire Posted May 9, 2015 Report Share Posted May 9, 2015 I use all of the above and yes, you do need a small tool to remove the batteries. I think that is because Denecke knows that the slate will not always be treated in gentle manner and keeping the power connected is paramount. Quote Link to comment Share on other sites More sharing options...
Toy Robot Posted May 9, 2015 Report Share Posted May 9, 2015 I use all of the above and yes, you do need a small tool to remove the batteries. I think that is because Denecke knows that the slate will not always be treated in gentle manner and keeping the power connected is paramount. +1 Quote Link to comment Share on other sites More sharing options...
efksound Posted May 9, 2015 Report Share Posted May 9, 2015 Ok I see, it just makes removing the sled and replacing it with a new one with fresh batteries a bit slower when you are in the heat of the battle :-) Quote Link to comment Share on other sites More sharing options...
Ze Frias Posted May 9, 2015 Report Share Posted May 9, 2015 I'll be using these now exclusively in talent TX, with my white Eneloops now relegated to ERXs, slates and other AA purposes. Alex, this is exactly what I do. Black envelops on talent TX, and white for pretty much everything else. Haven't looked back. Quote Link to comment Share on other sites More sharing options...
al mcguire Posted May 9, 2015 Report Share Posted May 9, 2015 try to have a spare sleeve loaded and ready to go into the heat of battle Quote Link to comment Share on other sites More sharing options...
Johnny Karlsson Posted May 10, 2015 Report Share Posted May 10, 2015 try to have a spare sleeve loaded and ready to go into the heat of battle Or change batteries before the battle (every other day in the morning) - they are rechargeable ! Quote Link to comment Share on other sites More sharing options...
osa Posted January 24, 2016 Report Share Posted January 24, 2016 Does anyone here possibly have runtimes on LT's or LTH's single battery use on these black eneloop pro's? I have no experience w LT's but i can only assume not so good results esp at 50 and 125mw. Hoping i might be wrong -Ken Quote Link to comment Share on other sites More sharing options...
berniebeaudry Posted January 24, 2016 Report Share Posted January 24, 2016 I have the LTs and use the black Eneloops. There was an update on my LTs for a component that was drawing too much power. I haven't had the opportunity to do a serious run time test since I got them back but previously I would get roughly four hours on 50mw. Im sure its better now. Quote Link to comment Share on other sites More sharing options...
Chandler H Posted June 8, 2017 Report Share Posted June 8, 2017 What setting are you guys using to best read voltage on Lectro Src and Srb's with the black eneloop pro? In your TX? AALithium seems to make them read low from the beginning..Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
RCarew Posted June 9, 2017 Report Share Posted June 9, 2017 AAT is the setting to use 1 hour ago, Chandler H said: What setting are you guys using to best read voltage on Lectro Src and Srb's with the black eneloop pro? In your TX? AALithium seems to make them read low from the beginning.. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Chandler H Posted June 9, 2017 Report Share Posted June 9, 2017 ThanksSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
resoNate3973 Posted May 1, 2018 Report Share Posted May 1, 2018 On 4/8/2015 at 11:39 PM, soundtrane said: i've used the iPower 9V for ages, and then found some chinese stuff which actually has been working VERY well... much cheaper about 5$ each. seriously good, says 720 mAh... for AA - Eneloop Black... What's the cheap chinese stuff called? Quote Link to comment Share on other sites More sharing options...
soundtrane Posted May 7, 2018 Report Share Posted May 7, 2018 On 5/2/2018 at 5:11 AM, resoNate3973 said: What's the cheap chinese stuff called? there are a number of names. EBL is one of them... Quote Link to comment Share on other sites More sharing options...
KRF Posted May 7, 2018 Report Share Posted May 7, 2018 I have been using KentLi lithium ion AA batteries for approaching 18 months now. They give me three hours in SMVs at 100 with around half an hour extra. This is the same as I was getting with Eneloop black. Quote Link to comment Share on other sites More sharing options...
IronFilm Posted May 8, 2018 Report Share Posted May 8, 2018 On 5/2/2018 at 11:26 AM, resoNate3973 said: What's the cheap chinese stuff called? I'm using Soshine Quote Link to comment Share on other sites More sharing options...
jwill Posted May 17, 2018 Report Share Posted May 17, 2018 Ive been using Li Polymer 2600mWh I Power aa's and been getting 4 hrs on my smqvs at 100mw Quote Link to comment Share on other sites More sharing options...
Constantin Posted May 17, 2018 Report Share Posted May 17, 2018 1 hour ago, jwill said: Ive been using Li Polymer 2600mWh I Power aa's and been getting 4 hrs on my smqvs at 100mw Only 4 hours? With black Eneloops I‘m getting at least 8 hours Quote Link to comment Share on other sites More sharing options...
Dalton Patterson Posted May 17, 2018 Report Share Posted May 17, 2018 Powerex and EBL all day. The day a cell or charger fails I will post all about it. Quote Link to comment Share on other sites More sharing options...
jwill Posted May 21, 2018 Report Share Posted May 21, 2018 they will go 8.... Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted May 21, 2018 Report Share Posted May 21, 2018 Do the Eneloops swell up enough in use that they are hard to get out of Lectro SM-series TX after they get hot? Sound Devices mixers and recorders? Quote Link to comment Share on other sites More sharing options...
afewmoreyears Posted May 21, 2018 Report Share Posted May 21, 2018 I have never had any of the Black Eneloop pros swell in any of my gear... SD, Lectro, Denecke etc.. Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted May 21, 2018 Report Share Posted May 21, 2018 Just now, afewmoreyears said: I have never had any of the Black Eneloop pros swell in any of my gear... SD, Lectro, Denecke etc.. Excellent, thanks. Quote Link to comment Share on other sites More sharing options...
