Scott Selman
Rechargeable Batteries for TX
You can always check the life with maha charger
That probably makes a lot more sense than the date system. I'm sure my usage is kind of uneven, and some batteries probably just have better insulation and will therefore last longer.
Although I have not been disappointed with my older white Eneloops, I bought a 4-pack of the black Sanyo Eneloop Pros after reading people's great experiences. Tried them out in my SMQVs and immediately ordered 16 more.
I'll be using these now exclusively in talent TX, with my white Eneloops now relegated to ERXs, slates and other AA purposes.
Sorry for the small off topic, but what kind of rechargeables are you guys using with a TS-C slate ? With Eneloops, amazon, duracells, I have a hardtime inserting the battery sled in the compartment and it's impossible to get it out without using a tool.
I use all of the above and yes, you do need a small tool  to remove the batteries.
I think that is because Denecke knows that the slate will not always be treated in  gentle manner and keeping the power connected is paramount.
+1
Ok I see, it just makes removing the sled and replacing it with a new one with fresh batteries a bit slower when you are in the heat of the battle :-)
Alex, this is exactly what I do. Black envelops on talent TX, and white for pretty much everything else. Haven't looked back.
Does anyone here possibly have runtimes on LT's or LTH's single battery use on these black eneloop pro's? I have no experience w LT's but i can only assume not so good results esp at 50 and 125mw. Hoping i might be wrong
-Ken
I have the LTs and use the black Eneloops. There was an update on my LTs for a component that was drawing too much power. I haven't had the opportunity to do a serious run time test since I got them back but previously I would get roughly four hours on 50mw. Im sure its better now.
What setting are you guys using to best read voltage on Lectro Src and Srb's with the black eneloop pro? In your TX? AALithium seems to make them read low from the beginning..
AAT is the setting to use
On 4/8/2015 at 11:39 PM, soundtrane said:
i've used the iPower 9V for ages, and then found some chinese stuff which actually has been working VERY well... much cheaper about 5$ each. seriously good, says 720 mAh...
for AA - Eneloop Black...
What's the cheap chinese stuff called?
there are a number of names. EBL is one of them...
I have been using KentLi lithium ion AA batteries for approaching 18 months now. They give me three hours in SMVs at 100 with around half an hour extra. This is the same as I was getting with Eneloop black.
I'm using Soshine
1 hour ago, jwill said:
Ive been using Li Polymer 2600mWh  I Power aa's and been getting 4 hrs on my smqvs at 100mw
Only 4 hours? With black Eneloops I‘m getting at least 8 hours
