pinkywinkieOZ Posted August 18, 2015 Report Share Posted August 18, 2015 I just learned that the nomad touch will require the nomad's serial port to connect. I'm currently using an FP8 - which hooks in to my nomad's serial port. I'd love to get a nomad touch once it's out, but does this mean that I can't use my FP8 at the same time as the touch? Quote Link to comment Share on other sites More sharing options...
MRWsound Posted August 18, 2015 Report Share Posted August 18, 2015 Hi PinkywinkieOZ, You won't be able to use the Touch and the FP8 at the same time. There is the future possibility of a Serial "hub" similar to what will be found in the Oasis. Quote Link to comment Share on other sites More sharing options...
Wandering Ear Posted August 19, 2015 Report Share Posted August 19, 2015 I was under the impression the touch connects through the USB port, not the serial port, so you will be able to use it with a fp8 Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted August 19, 2015 Report Share Posted August 19, 2015 it connects through serial port. Quote Link to comment Share on other sites More sharing options...
pindrop Posted August 19, 2015 Report Share Posted August 19, 2015 (edited) it connects through serial port. To the serial port via a USB style connector in the Nomad on one end, and to a USB port on the tablet on the other end yes? Hence why it's good to have a,very hard to come by, small (7" or 8") tablet with two USB ports, one for the data, and one for simultaneous charging yes? Edited August 19, 2015 by pindrop Quote Link to comment Share on other sites More sharing options...
ramallo Posted August 20, 2015 Report Share Posted August 20, 2015 I was in a thinking of buy a FP8, but I stopped it awaiting news (Such as a FP8 with hub) Quote Link to comment Share on other sites More sharing options...
pindrop Posted August 20, 2015 Report Share Posted August 20, 2015 Will a hub be released at the same time as Touch or at a later date? Quote Link to comment Share on other sites More sharing options...
DodoHu Posted August 20, 2015 Report Share Posted August 20, 2015 It's me nagging again with my old dream: Will we see an updated TRX742 with TC/monitor out this year? Still resisting to buy myself the TRX742 as it is, as I really, really want that plug. It would make the greatest sound solution for small cameras like dslrs ever! Quote Link to comment Share on other sites More sharing options...
Glen Deakin Posted August 20, 2015 Report Share Posted August 20, 2015 I have a question regarding the 742 transmitter and an ERX receiver. When using the eRx to monitor the 742 transmitter what is the usual range people can get off that I know zaxcoms website says less than 20 feet but I was just wondering what realistic real world experience is. Quote Link to comment Share on other sites More sharing options...
Nate C Posted August 20, 2015 Report Share Posted August 20, 2015 Glen from my tests in my home I was getting about 6-10 feet before i was getting dropouts. Tried it in different rooms and sometimes I could get a little more, but not much. I only tested with one frequency, so not an overly thorough test. Quote Link to comment Share on other sites More sharing options...
Glen Deakin Posted August 20, 2015 Report Share Posted August 20, 2015 Thanks. My idea is to use it for b-roll on the same frequency as my link to camera so I can just run around with the boom and not the full setup. Really I just want to be able to monitor while I'm sending the wireless to camera. Yes I would be turning my bag wireless link off when doing b-roll Thanks. Quote Link to comment Share on other sites More sharing options...
Nate C Posted August 20, 2015 Report Share Posted August 20, 2015 That should work fine. Manually hit record on the 742 and you've got a back up. I tested it to use as a small recorder to collect atmos's while on holidays this week in the country. Alas I forgot to pack it. Quote Link to comment Share on other sites More sharing options...
Glen Deakin Posted August 21, 2015 Report Share Posted August 21, 2015 I'm also thinking to use for a ms setup with my cinela pianissimo. I'm guessing monitoring is only going to be the mid microphone. Quote Link to comment Share on other sites More sharing options...
Abe Dolinger Posted August 21, 2015 Report Share Posted August 21, 2015 Slightly off topic, I've had very good luck lately with the frequency 2424 for Zaxnet. Most routers broadcast on channels 1, 6, or 11, and since 2.4Ghz broadcast works across multiple channels, 2424 and 2450 are most likely to be clean from nearby wifi. Wifi channel graph for explanation: Quote Link to comment Share on other sites More sharing options...
Jason A Posted August 21, 2015 Report Share Posted August 21, 2015 Slightly off topic, I've had very good luck lately with the frequency 2424 for Zaxnet. Most routers broadcast on channels 1, 6, or 11, and since 2.4Ghz broadcast works across multiple channels, 2424 and 2450 are most likely to be clean from nearby wifi. Wifi channel graph for explanation: Great tip Abe! I've been on 2464 as a default. No real logic to it except to keep on even numbers. There was word from Zax a while back that even numbered 2.4 freqs were yielding slightly better performance. I'll try the 2424 and see how it goes. j Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted August 21, 2015 Report Share Posted August 21, 2015 (edited) I'm also thinking to use for a ms setup with my cinela pianissimo. I'm guessing monitoring is only going to be the mid microphone. I used sanken CSS-5 with 742 and erx in a situation where mobility was required. One thing to be aware is you can not connect the 742 directly in most microphones. get a short boom and put it on the bottom Edited August 21, 2015 by RadoStefanov Quote Link to comment Share on other sites More sharing options...
Glen Deakin Posted August 21, 2015 Report Share Posted August 21, 2015 I used sanken CSS-5 with 742 and erx in a situation where mobility was required. One thing to be aware is you can not connect the 742 directly in most microphones. get a short boom and put it on the bottom Even with an MKH30/8040/8050 with a cinela? Slightly off topic, I've had very good luck lately with the frequency 2424 for Zaxnet. Most routers broadcast on channels 1, 6, or 11, and since 2.4Ghz broadcast works across multiple channels, 2424 and 2450 are most likely to be clean from nearby wifi. Wifi channel graph for explanation: Cool tip Thanks Quote Link to comment Share on other sites More sharing options...
ao Posted August 21, 2015 Report Share Posted August 21, 2015 Slightly off topic, I've had very good luck lately with the frequency 2424 for Zaxnet. Most routers broadcast on channels 1, 6, or 11, and since 2.4Ghz broadcast works across multiple channels, 2424 and 2450 are most likely to be clean from nearby wifi. Wifi channel graph for explanation: abe, do move this to a separate topic so that we can share tips and experiences Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted August 21, 2015 Report Share Posted August 21, 2015 (edited) Even with an MKH30/8040/8050 with a cinela? Cool tip Thanks Will test today if I have the time... I use mkh8060 mkh8040 with AES mzd8000 and have no problems. Edited August 21, 2015 by RadoStefanov Quote Link to comment Share on other sites More sharing options...
Wandering Ear Posted August 21, 2015 Report Share Posted August 21, 2015 I use my 742 occasionally with a schoeps ms setup and only a short xlr5 to 2x xlr3 cable. Works great and very compact. I think the erx monitoring is a sum of both mics, but I could be wrong about that, it's been a few months since I last used it this way. Quote Link to comment Share on other sites More sharing options...
VASI Posted August 27, 2015 Report Share Posted August 27, 2015 http://zaxcom.com/products/rx200 Yes!!! A different screen. +1 Quote Link to comment Share on other sites More sharing options...
Glen Deakin Posted August 27, 2015 Report Share Posted August 27, 2015 http://zaxcom.com/products/rx200 Yes!!! A different screen. +1 now that's a sweet unit. Looks like side meter aswell. Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted August 27, 2015 Author Report Share Posted August 27, 2015 now that's a sweet unit. Looks like side meter aswell. yes there is Quote Link to comment Share on other sites More sharing options...
Glen Deakin Posted August 28, 2015 Report Share Posted August 28, 2015 yes there is only 1 meter? Is it the same as on the qrx? Or is it different? Do you choose which channel you want to see on the side meter? Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted August 28, 2015 Author Report Share Posted August 28, 2015 It is a bank of 3 leds - same ones that are in the qrx. Quote Link to comment Share on other sites More sharing options...
