foliver Posted April 25, 2015 Report Share Posted April 25, 2015 Hello group, I'm having some bad issues with bolt systems ( 5 antennas ones). Until now, and under "normal " situation i worked this way: From the Cantar to the Alexas with a G2 for a ref sound, then sound goes with image by SDI to teradek to video assist, then from video assist to client director with another G2. Everything was ok, until some new teradek bolts with 5 antenas receiver comes into the camera equipment. The problem: The wireless signal going from the camera to the video assist is clean for picture but sound is having a ciclic heavy pffffff growing from clean to disaster first in right channel then in both, then clean again, then disaster. I would like to know if someone has had the same issue, and has find a solution for this. I like to avoid another receiver for video assist, and now i'm forced to use one like before the sdi. Thanks for share your experiences. Fabian Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted April 25, 2015 Report Share Posted April 25, 2015 Are the new Teradeks on the same freqs as the old? It sounds like they are steppping on your G2? I just wrapped a job with Teradeks on all cams and all cams with G2 RX, and it was all good. DIT told me that Teradek is very helpful, maybe call ro email them? philp Quote Link to comment Share on other sites More sharing options...
foliver Posted April 26, 2015 Author Report Share Posted April 26, 2015 Hi Philip how are you, txs for your answer. As far as i know teradeks tx are in the ghz, and my g2 on 660 mhz, so direct interference is not the problem, plus sound on camera is good. Free of interference. The problem is in the wireless sdi "travel"... Quote Link to comment Share on other sites More sharing options...
Nick Ray Harris Posted April 26, 2015 Report Share Posted April 26, 2015 I've scene RF spill off from teradeks ruin G3 signal. And cause weird noise I've never heard on wireless before Quote Link to comment Share on other sites More sharing options...
efksound Posted April 26, 2015 Report Share Posted April 26, 2015 Hi Fabian I have experienced the same issues with the same teradek system and same workflow. Works fine until suddenly sound starts to become garbled, and picture is clean. I came to the conclusion that it must be a firmware problem on these units. The only solution I found was to power cycle the Teradek units, after that everything started to work fine again. But I think it happened a few times during the day. Enviado desde mi Nexus 4 mediante Tapatalk Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted April 26, 2015 Report Share Posted April 26, 2015 No, no direct freq interference of course, but you have a problem, right? So something in the operation of the Teradeks has changed, and probably they are emitting something that is squashing your RX. Are the power and signal cables to the Teradek the same as used before, routed the same? Are they touching the G2? philp Quote Link to comment Share on other sites More sharing options...
foliver Posted April 26, 2015 Author Report Share Posted April 26, 2015 Thanks efk, and Philip. Philip, the g2 receiver has no interference, the sound recorded on camera is clean, the one that outputs the sdi coming from the teradek receiver is bad... Quote Link to comment Share on other sites More sharing options...
pkautzsch Posted April 26, 2015 Report Share Posted April 26, 2015 We have similar trouble, but most times it's just that when REC is pushed on one of our Alexas, the Teradek drops out completely. No cause to be found out, each component was exchanged. Video op is convinced it's Voodoo. Quote Link to comment Share on other sites More sharing options...
