MCooper Posted May 15, 2015 Report Share Posted May 15, 2015 So I've got a live recording gig coming up - a radio play, ala Prairie Home Companion, and I wanted your advice on the type, amount, and placement of audience microphones. I have access to a couple 416's, but there may also be a possibility to rent additional mics. The PA is hanging above the stage. What would be the best way to capture the audience in this small venue? Check out the attached picture. Thanks! Quote Link to comment Share on other sites More sharing options...
VASI Posted May 15, 2015 Report Share Posted May 15, 2015 Where the camera going to look and what ("which"; more correct?) is the perspective? I will give them three options: - One for general (mics to ceiling looking down to the audience). - Audience POV (mics looking to the band, possible stereo technique or LCR). - Band POV (mics looking to the audience, possible stereo technique or LCR). Mics: Possible omni (from ceiling), supercardioid. Main cardioids. Sorry for my english. Vasileios Quote Link to comment Share on other sites More sharing options...
MCooper Posted May 15, 2015 Author Report Share Posted May 15, 2015 Oh, I suppose I should add that this is an audio-only recording. No cameras, as far as I know. Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted May 15, 2015 Report Share Posted May 15, 2015 In a place that small all of your mics will hear the audience pretty much, all you need is some sweetener mics thay can pull up for applause or laughs in post, unless there is some possibility of verbal interaction between audience members and performers. For the former a pair of 416s will be fine, try to pattern off the PA speakers as bet you can depending on where the venue lets you mount them (go for general audience audio, like no specific people). The latter is much tougher, you may need several spot mics plus an operated shotgun somewhere. I recall that Ed Greene used to stud the stage lip of venues he was recording in with small mics (like Omnimax) so he could pull up specific people in the front row if a camera went for them in CU. philp Quote Link to comment Share on other sites More sharing options...
VASI Posted May 15, 2015 Report Share Posted May 15, 2015 Sorry Michael. I was misunderstanding. Mics from ceiling or from stage (looking to the audience) isn't a bad idea; I think. Try to not pick up "specific people" as Mr. Perkins said. Vasileios Quote Link to comment Share on other sites More sharing options...
MCooper Posted May 15, 2015 Author Report Share Posted May 15, 2015 Thanks, Philip. Do you think it would be better to place the mics on stands on each side of the stage, or (if venue willing) mount them on the ceiling grid on the inner (or outer) sides of the speakers? I do not believe it will be important to pick out specific people in the crowd. Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted May 16, 2015 Report Share Posted May 16, 2015 I go for stands mostly, so they can be moved if they've ended up in a bad spot w/o much hassle, and for speed of setup etc. In a space this small you may have to rig due to limited floor space…. p Quote Link to comment Share on other sites More sharing options...
Constantin Posted May 16, 2015 Report Share Posted May 16, 2015 I'd also consider to not set them up in a stereo config necessarily. Have one mic in the front the other further in the back. This way, if someone does participate from the audience you have more coverage, plus front audience and back audience may sound really different, allowing you to have both and mix and match both. Plus, if both mics capture distinctly different sounds, you could create a much greater stereo image later on (even though it's front/back). Have them overlap a bot in the stereo pan and the room could appear much larger and the audience bigger as a result. Quote Link to comment Share on other sites More sharing options...
