ek4 Posted May 20, 2015 Report Share Posted May 20, 2015 hi there, can someone bring some light into this.. when recording just to 6 iso tracks with 6 channels, is it possible to have the trims from the channels on the faders of the unit? or do you have to use this "auto mix "feature to trim a certain channel? i remember that when the nomads came out, the trim on the faders were not possible.. but now i heared that it is.. has it really changed? did not understood the manual there, sorry! (an never had the nomad in my hands..:-() Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted May 20, 2015 Report Share Posted May 20, 2015 Yes you can assign a fader knob to control trim, remote control gain on a wireless transmitter or be a fader. Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted May 20, 2015 Report Share Posted May 20, 2015 Trim on faders has been removed. It use to be option T on fader assign. I miss that option for when I record stereo and want to control 2 channels trim with one fader. Quote Link to comment Share on other sites More sharing options...
Chris Woodcock Posted May 20, 2015 Report Share Posted May 20, 2015 Trim on faders has been removed. It use to be option T on fader assign. I miss that option for when I record stereo and want to control 2 channels trim with one fader. You out Jack'd Jack Norflus what's going on here :-/ Quote Link to comment Share on other sites More sharing options...
Jason A Posted May 20, 2015 Report Share Posted May 20, 2015 2nd this for exactly the same reason. Handy for stereo/multichannel recording for sure. J Trim on faders has been removed. It use to be option T on fader assign. I miss that option for when I record stereo and want to control 2 channels trim with one fader. Quote Link to comment Share on other sites More sharing options...
pindrop Posted May 20, 2015 Report Share Posted May 20, 2015 Has been put back with experimental firmware v7.28T on Zaxcom forum. Though not on the date it claims? In fact Howy's dates are puzzling? 7.28T Jan 21 2015 experimental version to allow multiple trims one a single fader Quote Link to comment Share on other sites More sharing options...
ramallo Posted May 20, 2015 Report Share Posted May 20, 2015 Has been put back with experimental firmware v7.28T on Zaxcom forum. Though not on the date it claims? In fact Howy's dates are puzzling? 7.28T Jan 21 2015 experimental version to allow multiple trims one a single fader The problem is: or trims or FP8 I guess this issue need a new approach such as "trim groups" (like compressor groups) Quote Link to comment Share on other sites More sharing options...
Jason A Posted May 21, 2015 Report Share Posted May 21, 2015 Compressor groups? I was just looking for this option last week. Linking compressors for stereo/multichannel recording. For some reason I thought this had been implemented already but couldn't find it anywhere so I guess not. Using iso atten. is a workaround, but would be nice to be able to link as well. The problem is: or trims or FP8 I guess this issue need a new approach such as "trim groups" (like compressor groups) Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted May 21, 2015 Report Share Posted May 21, 2015 In the input setup menu you can set the compressors to a group. Quote Link to comment Share on other sites More sharing options...
Jason A Posted May 21, 2015 Report Share Posted May 21, 2015 Right. I was thinking about the post A/D, track compressors. In the input setup menu you can set the compressors to a group. Quote Link to comment Share on other sites More sharing options...
ek4 Posted May 21, 2015 Author Report Share Posted May 21, 2015 thanks to all! so it is possible, but just with the experimental firmware.. but.. when saying experimental firmware, what could be the flaws? minor things? or loosing entire recordings? Quote Link to comment Share on other sites More sharing options...
ramallo Posted May 21, 2015 Report Share Posted May 21, 2015 thanks to all! so it is possible, but just with the experimental firmware.. but.. when saying experimental firmware, what could be the flaws? minor things? or loosing entire recordings? Don't worry, works well Quote Link to comment Share on other sites More sharing options...
