Matt Radlauer Posted May 30, 2015 Report Share Posted May 30, 2015 I ran into this exact situation on a show I did last year..However it was with A LOT more people. 5 main cast members and each cast had supporting people 2-3 each. Our absolutely truly fantastical amazing EP just had to be able to dial in to every single cast member...individually whenever she wanted. We dodged a bullet and put her little pipe dream to bed when she found out how much it was going to cost for an IFB TX for 11-17 people! She had to settle for a lousy comtek feed from each mixer...poor lady. In this situation we could have used another entire sound mixer just to run IFB feeds... Quote Link to comment Share on other sites More sharing options...
Derek H Posted May 30, 2015 Report Share Posted May 30, 2015 I ran into this exact situation on a show I did last year..However it was with A LOT more people. 5 main cast members and each cast had supporting people 2-3 each. Our absolutely truly fantastical amazing EP just had to be able to dial in to every single cast member...individually whenever she wanted. We dodged a bullet and put her little pipe dream to bed when she found out how much it was going to cost for an IFB TX for 11-17 people! She had to settle for a lousy comtek feed from each mixer...poor lady. In this situation we could have used another entire sound mixer just to run IFB feeds... I think this is the answer to the question. Managing expectations. Quote Link to comment Share on other sites More sharing options...
Derek H Posted May 30, 2015 Report Share Posted May 30, 2015 I agree with Davidm Lectro should consider making one of these... Not so much so reality producers can spy on their cast but so you can use the same transmitter for the mix and IFB without quality loss. Quote Link to comment Share on other sites More sharing options...
Matt Radlauer Posted May 30, 2015 Report Share Posted May 30, 2015 I think this is the answer to the question. Managing expectations. TOTALLY! This ladies expectations were umm...out of this world ridiculous. We did our best to be polite and professional. Like I said it was an easy decision when they found out the cost..for ONE person to be able to hear every single mic was un-realistic. Quote Link to comment Share on other sites More sharing options...
bralleput Posted May 30, 2015 Report Share Posted May 30, 2015 (edited) Recorder/mixer with Easymix with one extra transmitter and receiver................?In the future directors and producers want to see the actual edit and mix on set.... Edited May 30, 2015 by bralleput Quote Link to comment Share on other sites More sharing options...
jason porter Posted May 30, 2015 Report Share Posted May 30, 2015 Handheld scanner is the best choice IMO, just pre program/label freqs and they are good to go. If I was starting from scratch, I think Zax wireless transmitters can be tuned to a single ERX over Zaxnet (regardless of UHF freq) Quote Link to comment Share on other sites More sharing options...
Storyhub Posted June 4, 2015 Report Share Posted June 4, 2015 I have used a UCR401 receiver with the freqs written on white gaff tape on the receiver for each talents transmitter. Headphones can plug directly to the receiver by using a TRS F to XLR F adapter plugged directly to the receiver or with an XLR mic cable. I often use this instead of an R1a for IFB on remote radio broadcasts. I often use UCR401s to feed guide track to cameras directly from a talent mic in a similar fashion. Quote Link to comment Share on other sites More sharing options...
Eric Posted June 8, 2015 Report Share Posted June 8, 2015 iCom products have been used in the past. Recently the IC-R6. Mic freqs can be programmed in for talent mics and (if i remember correctly) they can be tuned quickly with the turn of a knob or button. Quote Link to comment Share on other sites More sharing options...
thebrengun Posted June 8, 2015 Report Share Posted June 8, 2015 Just off the top of my head: If you dial in the switch setting to a frequency you can actually hear the UHF frequency but it is very very low. It would be noisy but you could amplify that. Then you could set all your talent tx into IFB mode and set the R1a to scan for them. Then switch them back. This is all highly theoretical as I don't have any units with me now to test. Like everyone said, a lot to expect and not easy to switch once set up Quote Link to comment Share on other sites More sharing options...
