DR 680 Battery Question
Hugh Palmer
On 7/8/2016 at 6:32 AM, enjoyfebruary said:
In just a general sense? Or specifically about powering it?
Curious as to what specific caveats there are when it comes to powering it that I need to watch out for?
At the moment I am using this ("Feelworld FW4600BP Rechargeable one Battery Pack 12V 4600mAh for Camera Monitor"):
http://www.ebay.com/itm/141802274265
1. As I recall, when the external battery gets real low, the machine will exiit record and stop w/o saving the file. AND the take counter reverts to previous arbitrary. If this goes unnoticed, it will overwrite the previous files WITHOUT warning.
2. If a new folder is selected and no file is written to it, if the machine is shut down, it reverts to the previous folder.
OTOH, if the power connection is pulled (by accident or otherwise ) it switches to the internal batteries w/o issue.. and the display's back light will extinguish (if so set).. an unintended warning system.
I don't currently recall a few other odd behavior issues since it was in 2013 I used the 680. Other than that, it performed splendidly. I used it in conjunction with a 442 and fed the #5 and 6 radio tracks line level. It's also one of the few machines that totally bypasses the mic preamps in line level. The SD card can also be hot-swapped as another consolation.
Make sure the latest firmware is installed which makes resetting the take counter much easier.
Although it would be designed differently now, when the DR-680 was created, that input was designed only to be used with the 12V AC power adapter, so it has no monitoring for gradual voltage decay that would happen when you feed it with an external battery based supply.  As you note, If you always have internal batteries installed, the auto-switch over mitigates the issue.
Noted, and this will be fixed in the next firmware version (currently in testing) for the DR-680 and DR-680mkII.
Ah, so is *very* important it sounds to have charged internal batteries in the DR680!
