Jeff Wexler Posted June 10, 2015 Report Share Posted June 10, 2015 My TentacleSync package arrived today --- wow, they are small! Setup from computer is very clear and simple (will be even easier when the iOS app is released). Looking forward to testing them out. Quote Link to comment Share on other sites More sharing options...
Nathaniel Robinson Posted June 10, 2015 Report Share Posted June 10, 2015 Good results from mine so far with Scarlet, C300, and F3. Only issue I've had is that the units seemingly can't store user bits. Awaiting confirmation from manufacturer about that. Quote Link to comment Share on other sites More sharing options...
Nate C Posted June 10, 2015 Report Share Posted June 10, 2015 Mine arrived a couple of days ago. Very impressed with them. Tiny and easy to use.Look forward to the app being released. Luckily I am in the land of Pal or 25fps. Alas I need to update my computer to try out the trial sync program. Quote Link to comment Share on other sites More sharing options...
callou Posted June 11, 2015 Report Share Posted June 11, 2015 I receive mine today , i installed a yosemite partition to test the software ..i will do some more extensive test soon but so far it seems to work very good..i only tried with only camera with an input i had in hand...my mac ...and it works!! ( it was 2 frame off but it my was fault cause i realize afterward that my mac shoot 29,97 fps and my nomad 25 ..) Quote Link to comment Share on other sites More sharing options...
Bash Posted June 11, 2015 Report Share Posted June 11, 2015 Hi Jeff and all, I think we would all be fascinated to find out about accuracy over time, so - might someone be able to run a Tentacle box against a Denecke or Ambient and see how the accuracy holds over a few hours? Many thanks, sb Quote Link to comment Share on other sites More sharing options...
michaelmoote Posted June 11, 2015 Report Share Posted June 11, 2015 Anyone had any luck jamming direct from a recorder in slave mode (and auto adjusting frame rate to master clock on recorder)? Mine don't, but works great in 25fps for now :( Quote Link to comment Share on other sites More sharing options...
michaelmoote Posted June 11, 2015 Report Share Posted June 11, 2015 Ulrich at tentacle tells me that feature will be implemented in a firmware update end of June. Quote Link to comment Share on other sites More sharing options...
Constantin Posted June 11, 2015 Report Share Posted June 11, 2015 I got my early bird a few weeks ago and picked up another bunch just Monday at Tentacle Sync HQ. Very nice operation they've got set up there. Started a shoot with them on Tuesday and so far no negative feedback, but it's only been a couple of days of course. Shooting with an Alexa, so this is probably the one scenario where the Tentacles can't shine quite as much. But a small success: the AC initially didn't want to leave the box on the camera. Too much stuff he said. But on day two he said, well they are so small, let's just leave them always connected. Excellent! The cable is a perfect length, too, by the way. Quote Link to comment Share on other sites More sharing options...
Nathaniel Robinson Posted June 11, 2015 Report Share Posted June 11, 2015 Anyone had any luck jamming direct from a recorder in slave mode (and auto adjusting frame rate to master clock on recorder)? Mine don't, but works great in 25fps for now I can jam from recorder but it won't auto adjust the frame rate. Tested with 23.98 and 29.97. Quote Link to comment Share on other sites More sharing options...
Armin Siegwarth Posted June 11, 2015 Report Share Posted June 11, 2015 Works with Epic Dragon, C300, 5D, 7D. Sync test: 8h against 664 - under one frame offset. All 4 I have the same, so they are very precise under each other. Quote Link to comment Share on other sites More sharing options...
Constantin Posted June 11, 2015 Report Share Posted June 11, 2015 Sync test: 8h against 664 - under one frame offset. All 4 I have the same, so they are very precise under each other. Or maybe, they just are precise and it's the 664 that's off? Quote Link to comment Share on other sites More sharing options...
Jeff Wexler Posted June 12, 2015 Author Report Share Posted June 12, 2015 I don't want to be guilty of using JWSOUND for technical support but this is a brand new product and I'm not sure TentacleSync even has technical support up and running. In any case, here goes: simplest test of all, I setup one TentacleSync box (via setup software) for 23.98 and jammed it from my Denecke GR-2. TentacleSync took the jam, no problem, series of 3 rapid flashes green until disconnect, then solid green, slow single flash as expected. I then jammed a Denecke slate from the box. Timecode is correct but NO DATE displayed (userbits) on slate close. Jamming the slate directly from GR-2, timecode is again correct and DATE is displayed on slate closing. Anybody have any idea why this is happening? Quote Link to comment Share on other sites More sharing options...
Olle Sjostrom Posted June 12, 2015 Report Share Posted June 12, 2015 Could it be user bits related? I dunno, but I read somewhere (this very thread?) that the tentacles doesn't support user bits. The only time I've ever thought of user bits was once when the date was of in metadata and that changes when I edited the user bits on some recorder.. just a 11pm going to bed thought Quote Link to comment Share on other sites More sharing options...
Constantin Posted June 13, 2015 Report Share Posted June 13, 2015 The user bits can bet set in the Tentacle setup software Quote Link to comment Share on other sites More sharing options...
Prahlad Strickland Posted June 13, 2015 Report Share Posted June 13, 2015 Keen to see how you all find this with the zaxcom maxx or Nomad, which are certainly famous for their drift over the period of a full day. Enough to be a problem?, love to hear any experiences. Quote Link to comment Share on other sites More sharing options...
Jeff Wexler Posted June 13, 2015 Author Report Share Posted June 13, 2015 The user bits can bet set in the Tentacle setup software I heard from the TentacleSync people that userbits has yet to be implemented. There will be an update, soon, that supports userbits, but for now it's a no show. Quote Link to comment Share on other sites More sharing options...
Jeff Wexler Posted June 13, 2015 Author Report Share Posted June 13, 2015 Keen to see how you all find this with the zaxcom maxx or Nomad, which are certainly famous for their drift over the period of a full day. Enough to be a problem?, love to hear any experiences. I have never had any drift or any timecode problems with any of my Zaxcom gear --- I really only wound up with the TentacleSync devices because I participated in their Indiego campaign --- I think it is a really nice product (even though I probably do not have a use for it at this time). If, in the past, I had ever had any problems with Zaxcom and timecode, I could have used any one of a number of outboard timecode devices. Never had the need and I can't imagine that I would use the TentacleSync box to deal with a problem I haven't had. Quote Link to comment Share on other sites More sharing options...
berniebeaudry Posted June 13, 2015 Report Share Posted June 13, 2015 Keen to see how you all find this with the zaxcom maxx or Nomad, which are certainly famous for their drift over the period of a full day. Enough to be a problem?, love to hear any experiences. My Nomad 10 doesn't drift. Quote Link to comment Share on other sites More sharing options...
Chris Woodcock Posted June 13, 2015 Report Share Posted June 13, 2015 My Nomad 10 doesn't drift. No drift issues here on my nomad either. Quote Link to comment Share on other sites More sharing options...
Chris Woodcock Posted June 13, 2015 Report Share Posted June 13, 2015 Quote Link to comment Share on other sites More sharing options...
Constantin Posted June 13, 2015 Report Share Posted June 13, 2015 I heard from the TentacleSync people that userbits has yet to be implemented. There will be an update, soon, that supports userbits, but for now it's a no show. Yes, seems like you're right. I was so sure I saw a box in the setup software to enter the UserBit into, but now I can't find that box anymore. No idea where I got that from. Maybe it was a dream... Quote Link to comment Share on other sites More sharing options...
Constantin Posted June 13, 2015 Report Share Posted June 13, 2015 (edited) No drift issues here on my nomad either. how do you know this? Edited June 13, 2015 by Constantin Quote Link to comment Share on other sites More sharing options...
Jeff Wexler Posted June 13, 2015 Author Report Share Posted June 13, 2015 Constantin: the way I know I have not had any drift is the fact that no one in post has ever even mentioned any discrepencies between my tracks, the slates and the camera (with cameras usually having a sync box, Denecke or Ambient, jammed from my recorder. I don't think the people in post are just being kind and not wanting to upset me --- the timecode systems just as worked, as they should, and everything synced up properly. I have never felt the need to do any of my own bench testing and comparisons. Maybe I've just been lucky? Quote Link to comment Share on other sites More sharing options...
Chris Woodcock Posted June 14, 2015 Report Share Posted June 14, 2015 how do you know this? Exactly what Jeff said, never had the nomad and the slate drift from each other. Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted June 14, 2015 Report Share Posted June 14, 2015 Keen to see how you all find this with the zaxcom maxx or Nomad, which are certainly famous for their drift over the period of a full day. Enough to be a problem?, love to hear any experiences. As someone who has owned a Nomad for more than a couple of years (and three Devas, for that matter), and keeps a pretty close eye on the operational characteristics of the many tools I use, I'm a bit curious as to how I'm so blissfully unaware of this "certainly famous" drift claimed in the above statement. Perhaps some specific documentation would shed light on this apparently well-guarded secret. Quote Link to comment Share on other sites More sharing options...
