Joe Riggs Posted June 25, 2015 Report Share Posted June 25, 2015 (edited) Sound mixer didn't record poly files, so I'm left with a bunch of separate mono files for every take, which I'd like to combine into polys. What's the most efficient workflow with Wave Agent to do so? Is it possible to bring in ALL sound files for day 1 and it will create polys? Or do I have to keep it take by take? So Take 1, bring in the three separate mono files, combine...Take 1A, bring in the three separate mono files, combine, and so on. Thank you Edited June 25, 2015 by Joe Riggs Quote Link to comment Share on other sites More sharing options...
Will Youngman Posted June 25, 2015 Report Share Posted June 25, 2015 Wave agent should automatically group the mono files together. Go to split/combine->Combine-> Tell it where to go-> Process. If wave agent is not able to group them together than you have bigger problems. Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted July 9, 2015 Report Share Posted July 9, 2015 Wave agent can combine to a poly file if the individual files have identical start times. Quote Link to comment Share on other sites More sharing options...
pindrop Posted July 9, 2015 Report Share Posted July 9, 2015 Wave agent can combine to a poly file if the individual files have identical start times. Plus WA can do it as a batch, if in the same folder, and will work it's way through until done. Quote Link to comment Share on other sites More sharing options...
