MATT CLEARY Posted July 1, 2015 Report Share Posted July 1, 2015 Is the Lectrosonics WM tx still watertight when used with the ACOAXTX remote antenna? Does the sma connecter in the antenna have an o-ring or something to stop water entering? If not, how is the standard antenna made watertight? Quote Link to comment Share on other sites More sharing options...
ryanpeds Posted July 1, 2015 Report Share Posted July 1, 2015 I just used the WM a couple weeks ago, the one with the removable antenna. You can use any sma antenna with it. Lectrosonics website says that it uses a "compression sealed antenna port". Quote Link to comment Share on other sites More sharing options...
WesH Posted July 2, 2015 Report Share Posted July 2, 2015 Hi Matt, Is the Lectrosonics WM tx still watertight when used with the ACOAXTX remote antenna? Does the sma connecter in the antenna have an o-ring or something to stop water entering? If not, how is the standard antenna made watertight? Ryan is correct regarding the sealed antenna port on the transmitter -- the WM itself is watertight, regardless of the antenna used. Our AMM series of antennas do indeed have an O-ring seal in its internal construction. The ACOAXTX antenna is also watertight; I imagine there is an O-ring in the construction of that particular antenna though I've never torn one apart to see how it's put together. Best, Wes Herron Lectrosonics, Inc. Quote Link to comment Share on other sites More sharing options...
