Lectro WM with ACOAXTX remote ant. Still waterproof?
MATT CLEARY
Hi Matt,
Is the Lectrosonics WM tx still watertight when used with the ACOAXTX remote antenna? Does the sma connecter in the antenna have an o-ring or something to stop water entering? If not, how is the standard antenna made watertight?
Ryan is correct regarding the sealed antenna port on the transmitter -- the WM itself is watertight, regardless of the antenna used.  Our AMM series of antennas do indeed have an O-ring seal in its internal construction.  The ACOAXTX antenna is also watertight; I imagine there is an O-ring in the construction of that particular antenna though I've never torn one apart to see how it's put together.
Best,
Wes Herron
Lectrosonics, Inc.
