Hugh Palmer Posted August 27, 2015 Report Share Posted August 27, 2015 (edited) I recently bought some secondhand Countryman EWM lavalieres and was hoping to re-terminate them to fit a Sennheiser G3. I received them today and am a little puzzled as to how to do this exactly. There is a huge preamp looking thing on the end which is essentially housed in the XLR. Having only worked with Sennheiser ME2s and DPAs I have never seen this before and am wondering where to take it from here.. Any advice would be great. https://goo.gl/photos/mdJ71CtwY77Zajy27 Edited August 27, 2015 by Hugh Palmer Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted August 27, 2015 Report Share Posted August 27, 2015 You have the power supply and xlr connector at the end of the cable which requires 48vp to power the EMW. If you're going to change the EMW for wireless use with a Sennheiser G series then cut off the power supply and then go to the Countryman website www.countryman.com and look up the wiring diagram for the EMW to the Sennheiser G series. You will need a 3.5mm TRS locking connector to connect to the transmitter. Quote Link to comment Share on other sites More sharing options...
Hugh Palmer Posted August 27, 2015 Author Report Share Posted August 27, 2015 Thanks Eric. I've found the wiring diagram and I have some of the 3.5mm connectors on order. I'm just wondering why it wouldn't require 48v when plugged into the the G3. Or does the transmitter put out a nominal voltage to power the microphone? Or is the end of that XLR a type of regulator that will drop the voltage down to the 5-9v that the countryman needs (assuming that the countryman needs lower voltages)? Sorry about all of the questions, just trying to wrap my mind around this. Quote Link to comment Share on other sites More sharing options...
jason porter Posted August 27, 2015 Report Share Posted August 27, 2015 That is exactly it. The "xlr barrel" has circuitry to drop the p48 to 3-5v, which would be typical for most lav mics. I recently rewired an EMW and I think it needs a resistor stuffed into the connector. Quote Link to comment Share on other sites More sharing options...
Hugh Palmer Posted August 27, 2015 Author Report Share Posted August 27, 2015 Ahh ok that makes sense to me then. Yeah they need a 6.8K resistor between the shield and ring as below. Appreciate your help! Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted August 28, 2015 Report Share Posted August 28, 2015 Ahh ok that makes sense to me then. Yeah they need a 6.8K resistor between the shield and ring as below. Appreciate your help! Actually they don't need the resistor for use with a Sennheiser G series TX. They work just fine without it. Quote Link to comment Share on other sites More sharing options...
