patoggt Posted October 9, 2015 Report Share Posted October 9, 2015 Hi, i m in need of advice. My Lectro system (UCR 210d and UM 200b) is giving me some hard time. Everything works perfect until past the half hour or so, i get a distortion in the singal. It sounds very similar to when you are going out of battery but keeps working with the distortion. After a few minutes the distortion goes away and everything goes back to normal. Always using rechargeable batteries on both Tx and Rx. Its hard to test it at home because it starts the distortion randomly and past the 30 minutes or so of use. Any advice would be greatly appreciated Quote Link to comment Share on other sites More sharing options...
karlw Posted October 9, 2015 Report Share Posted October 9, 2015 The problem could have any number of reasons, including either the transmitter or receiver needing an alignment, there could be moisture or corrosion in the transmitter microphone connector, or there could be internal damage or a failing component. Have you made sure the problem isn't from the lavaliere microphone? Moisture or a failing cable or connector could also be suspect. Quote Link to comment Share on other sites More sharing options...
