Matthias Richter Posted November 20, 2015 Report Share Posted November 20, 2015 was using my QRX in dual mode and received two actors on two TRXs. When one actor was finished we switched that TRX off. I still received the 2nd TRX on the QRX100 (showing RF signal and audio-signal) but no audio came through to my Nomad. After tuning RX A to the same freq as B I had actor B now on both channels and also audio came through on both outputs. Is this a known bug? Audio B gets muted when RX A gets no RF-signal? Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted November 20, 2015 Report Share Posted November 20, 2015 I haven't heard of that happening before. While I've don't use a QRX100, this has not happened with my 200s. As usual, more details help. What firmware do they have installed? Can you reproduce the event when testing later? Which modulation mode are you using? Quote Link to comment Share on other sites More sharing options...
Bertolomi Posted November 20, 2015 Report Share Posted November 20, 2015 hey matthias, I had some kind of the same bug after I switched to the 8 aes channel chip. First I thought it would be a heat problem but I found out, that the aes sync broke. After some really serious headahes I found out, that turning "sony f55" sync to "allways" fixed the issue for me. I hope this helps!! Greets from the other side of Berlin Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted November 20, 2015 Report Share Posted November 20, 2015 was using my QRX in dual mode and received two actors on two TRXs. When one actor was finished we switched that TRX off. I still received the 2nd TRX on the QRX100 (showing RF signal and audio-signal) but no audio came through to my Nomad. After tuning RX A to the same freq as B I had actor B now on both channels and also audio came through on both outputs. Is this a known bug? Audio B gets muted when RX A gets no RF-signal? Matthias, I have had this happened on a qrx200. I had to send it back to the factory. I msged you a how to check if the unit is working properly. hey matthias, I had some kind of the same bug after I switched to the 8 aes channel chip. First I thought it would be a heat problem but I found out, that the aes sync broke. After some really serious headahes I found out, that turning "sony f55" sync to "allways" fixed the issue for me. I hope this helps!! Greets from the other side of Berlin QRX100 and QRX200/235 have no heat issues. Believe me I have baked the hell out of Zaxcom in the desert where lectro SRa fail... Quote Link to comment Share on other sites More sharing options...
Matthias Richter Posted November 20, 2015 Author Report Share Posted November 20, 2015 hate to admit but that was pure user error. Quote Link to comment Share on other sites More sharing options...
David Marien Posted November 21, 2015 Report Share Posted November 21, 2015 Was it routing mistake on the nomad ? Could you elaborate in case that happens to us ? Thanks Quote Link to comment Share on other sites More sharing options...
Matthias Richter Posted November 22, 2015 Author Report Share Posted November 22, 2015 I had updated my QRX100 and set it to AES normal. Should been set to swapped because I use output 1 for both RXs. Since both mics were plant in a standing car I thought they just sound simular when I was listening to 1 mic on both Inputs. Thanks for the int recording I've got the 2nd plant still. Quote Link to comment Share on other sites More sharing options...
