Matt Mayer Posted November 27, 2008 Report Share Posted November 27, 2008 Well, Scott's not around, so I'll let everyone know that a new version of 788T firmware was posted today. Get the details at: http://www.sounddevices.com/notes/recorders/firmware/788t-1-60/ ---Matt Quote Link to comment Share on other sites More sharing options...
soundgirl Posted November 27, 2008 Report Share Posted November 27, 2008 Well, Scott's not around, so I'll let everyone know that a new version of 788T firmware was posted today. Get the details at: http://www.sounddevices.com/notes/recorders/firmware/788t-1-60/ ---Matt Wow, 12 tracks and CL8 activated, I hope my CL8 shows up soon. Thanks Sound Devices! Quote Link to comment Share on other sites More sharing options...
Mark LeBlanc Posted November 28, 2008 Report Share Posted November 28, 2008 Greetings, Just downloaded the latest firmware and it has a behavior that is a bit scary. First my normal setup, pretty straight forward Inputs 1-4 routed to tracks R/L/A/B. If channel 1 was turned on, just the simple act of turning on the channel armed the track for recording. I'm on a movie now where I'm swapping between 1 and 3 inputs at a moments notice. The disturbing new behavior is you MUST enter a menu and arm/disarm a track to get it to record. You now visit menus more often if you are changing setups often. Just afraid I'll miss a track because you still hear a track even if the track is NOT armed.. Just a heads up of the new way. Anyone know if you can downgrade firmware? Quote Link to comment Share on other sites More sharing options...
Chris R Posted November 28, 2008 Report Share Posted November 28, 2008 There are a couple changes Im not in love with.. but I actually like the way you arm tracks in the new version, simply hitting the input button and scroll to the track and push. Pretty quick for me, and I like that you dont have to turn the trims on and off and can leave it at the position you want. Greetings, Just downloaded the latest firmware and it has a behavior that is a bit scary. First my normal setup, pretty straight forward Inputs 1-4 routed to tracks R/L/A/B. If channel 1 was turned on, just the simple act of turning on the channel armed the track for recording. I'm on a movie now where I'm swapping between 1 and 3 inputs at a moments notice. The disturbing new behavior is you MUST enter a menu and arm/disarm a track to get it to record. You now visit menus more often if you are changing setups often. Just afraid I'll miss a track because you still hear a track even if the track is NOT armed.. Just a heads up of the new way. Anyone know if you can downgrade firmware? Quote Link to comment Share on other sites More sharing options...
studiomprd Posted November 28, 2008 Report Share Posted November 28, 2008 "... you can't please all of the people, ever!" SMM Quote Link to comment Share on other sites More sharing options...
Alan Posted November 28, 2008 Report Share Posted November 28, 2008 "... you can't please all of the people, ever!" SMM But.....but.......12 tracks!! wow !!! Kindly please explain the routing? 4 aux track?? ST MIX plus 2 AUX?? Alan Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted November 28, 2008 Report Share Posted November 28, 2008 But.....but.......12 tracks!! wow !!! Kindly please explain the routing? 4 aux track?? ST MIX plus 2 AUX?? Alan The manual for this version (new manual) is up on their site to (GO SD!) and p 24 explains it all pretty well. 8 iso, 2 more always post fade, 2 more pre or post routable per each. Pretty amazing. Philip Perkins Quote Link to comment Share on other sites More sharing options...
Alan Posted November 28, 2008 Report Share Posted November 28, 2008 The manual for this version (new manual) is up on their site to (GO SD!) and p 24 explains it all pretty well. 8 iso, 2 more always post fade, 2 more pre or post routable per each. Pretty amazing. Philip Perkins Thanks Phil, will do. Wondering will a HUI be release for the 788T instead of the CL8? Alan Quote Link to comment Share on other sites More sharing options...
Mark LeBlanc Posted November 29, 2008 Report Share Posted November 29, 2008 Ok, Spent the day with 1.60 in the bag and can comment a bit. 1. Turning the LCD on/off is a bit more work as now you have to Press the Illuminate button and press the Wheel.. 2. If you are running/gunning with quick changes I almost stumble by not arming a track. Caught it, but you have to be on your toes not simply plug in, turn on, turn on a channel and go. 3. The changes to the Folder/File accessing is nice 4. Didn't get a chance play with the extra tracks. I was bouncing between 1 boom and three lavs. In my Petrol bag having to scroll around and arm/disarm tracks really cries out for the CL8 to come into play.. Otherwise it was its usual rock solid performance. Mark L Quote Link to comment Share on other sites More sharing options...
FSBELLA Posted November 29, 2008 Report Share Posted November 29, 2008 Wow, 12 tracks and CL8 activated, I hope my CL8 shows up soon. Thanks Sound Devices! soundgirl, Fyi- pretty sure you can only record 8 trks, if you want to use the multiple recording formats. the 12 trks are for int.hd ( M.M.-clarify or verify please.) Gd Lk, Fs Quote Link to comment Share on other sites More sharing options...
Chris R Posted November 29, 2008 Report Share Posted November 29, 2008 soundgirl, Fyi- pretty sure you can only record 8 trks, if you want to use the multiple recording formats. the 12 trks are for int.hd ( M.M.-clarify or verify please.) Gd Lk, Fs from what I read it seems to be limited to 8 tracks if you use 3, internal, CF, and ex. at the same time. Quote Link to comment Share on other sites More sharing options...
Paul Isaacs Posted November 29, 2008 Report Share Posted November 29, 2008 Hi Folks, Just to set a few facts straight . . You can record 12 tracks simultaneously to 2 media and 8 tracks simultaneously to 3 media. Paul Principal Applications Engineer Sound Devices Quote Link to comment Share on other sites More sharing options...
Paul Isaacs Posted November 29, 2008 Report Share Posted November 29, 2008 In my Petrol bag having to scroll around and arm/disarm tracks really cries out for the CL8 to come into play.. Otherwise it was its usual rock solid performance. Mark L You're right! The new functionality of V1.60 is best tasted with a CL8 controller (now shipping) attached. Without the CL8, you still have access to all the new v1.60 functionality (with the exception of slatemic), however to get the best from this firmware release, we highly recommend using the CL8. The CL8 provides one-handed direct control of many functions like routing in/out of LR or Aux12, limiter, HPF, phase invert, solo, slatemic etc. We made track arming/disarming independent from input activation and routing because it provides more flexibility such as: - the ability to use a track as a mix/summing bus without having to waste disk space recording it - ideal for routing multiple inputs to a single output for ifb, comms, director feeds etc. - as Chris pointed out, a track can now be very quickly armed/disarmed without having to turn on/off inputs so now you can leave your trims at the position you've set. Access to track arming is quick - just press the INPUT button (no scrolling through the MENU necessary) and you can see all 12 tracks simultaneously and their metering, then just rotate the encoder to select track and press to toggle arming. From this screen, you can also access the master gain controls for the LR and AUX mixes. We also have added the ability to route/unroute inputs from armed or disarmed tracks during record. Turning the LCD on/off is a bit more work as now you have to Press the Illuminate button and press the Wheel.. Yes - pressing the light button on its own is now used to toggle the metering so that you can view 12 tracks on the led meters. Paul Principal Applications Engineer Sound Devices Quote Link to comment Share on other sites More sharing options...
bcopenhagen Posted November 29, 2008 Report Share Posted November 29, 2008 Glad to have you here, Paul (Isaacs). It's a wonderful pleasure of this forum to have many developers and designers answering questions directly. Thanks for your input. Since you bring up the slate mic, I would (and perhaps a few others) very much like to see the enabling of the slate mic thru some alternative means than only the CL8. I thought it might be an elegant implementation through either the built-in logic input, or the logic inputs on the CL-1. Much obliged, Brian Quote Link to comment Share on other sites More sharing options...
Mark LeBlanc Posted November 29, 2008 Report Share Posted November 29, 2008 Paul, Would you guys consider a routing preset that was a simple Inputs 1-4, routed to tracks LRAB and were armed by simply turning on the channel. I am looking at adding the CL-8, but it will be a few jobs before that can happen? Thanks, Mark Quote Link to comment Share on other sites More sharing options...
Paul Isaacs Posted November 29, 2008 Report Share Posted November 29, 2008 Thanks Mark, Brian for your good ideas. All suggestions are considered! Paul Quote Link to comment Share on other sites More sharing options...
Mark LeBlanc Posted November 30, 2008 Report Share Posted November 30, 2008 Paul, Forgot to ask, once you have update the firmware, can you downgrade? Thanks, Mark Quote Link to comment Share on other sites More sharing options...
Paul Isaacs Posted November 30, 2008 Report Share Posted November 30, 2008 Paul, Forgot to ask, once you have update the firmware, can you downgrade? Thanks, Mark Yes you can. Paul Quote Link to comment Share on other sites More sharing options...
Mark LeBlanc Posted December 1, 2008 Report Share Posted December 1, 2008 Paul Thanks for your assistance! Mark Quote Link to comment Share on other sites More sharing options...
