PedroAdamastor
What 9 volt rechargeables do you use? Li-ion or Nimh?
Hi, im planning to buy 2 ART MyMonitor (personal headphone monitor mixer) for my boom operators (so they can hear their boom without having to send them audio from the Sound Devices 664) (cant afford the Sound Devices MM-1 or Rolls PM55P now).
I will need to buy some 9v batteries and charger.
Should i go
Lithium Ion or Nickel-Metal Hydride? Never used Li ion rechargeable batts, whats the pros and cons?
Which ones you use and recommend?
I live in Europe, so it would be great to know a european store that has them.
Thanks
Pedro Adamastor
to answer your question - it depends. I generally go with Lithium but i believe the nickel would do better in colder environments. lithium would be lighter.
this is an interesting alternative to using an mm1 or duplex. Running the signal through this before it gets to your 664 (or what ever recorder you're using) does it affect the signal at all since it's running through another system/amp?
or is it a passive loop through - like i the rolls is?
..in which case it would be like connecting it to another xlr in the middle.
i imagine you could also use this as a phantom power box too..
1 hour ago, Shastapete said:
Side note: look at the Rolls PM50s, I have one and it works well. No noticeable issues from putting it inline with a boom mic, $45 each
Thanks Peter, but the Rolls PM50s dont run on batteries, just with power adapter right?
The PM55P has batteries but is 2x the price of the ART.
But im still looking for more information before i buy them.
By the way what 9v batts you use? And charger?
Thanks for the help.
Thanks for you post Zach.
I havent bought it yet, but i read this from a buyer review:
"I bought this device for a non-standard use, and it works very well. I record sound on location for a local tv show. My boom operator (when I use one) needs to be able to hear what's coming thru the boom mic. The MyMONITOR fills the need very well. The boom mic plugs into the input of the unit and another XLR cable runs to my mixer/recorder. The operator plugs in a set of headphones (there are two jacks), and we're off to the races. The unit passes phantom power to the mic with no issue."
I believe the XLR Mic Thru will not change the sound that goes from the mic to the mixer, but havent tested it yet.
runs on a single 9volt
I don't have much on 9v. But I have this: http://www.amazon.com/gp/product/B00EQ3U2AA?psc=1&redirect=true&ref_=oh_aui_detailpage_o02_s00
no complaints
hi Pedro,
I am using 520 mAh iPowerUS 9V rechargables (LiPO) for all my 9V needs. they outperform regular Alkalines by far, they are lightwight, charge quickly (like 1,5 hs max recharging time) and have a useful lifespan of more than two years (about 100 charges per year)
My local dealer here in Austria has them in stock, about 25 € each, add another 35,- for the charger maybe. It should be the decicated 4 bay iPower charger.
The NiMh 9 Volts are typically 100 mAh or so but some are as low as 7.2 Volts in use. Others can be 8.4 Volts (good) or 9.6 Volts (little high for some gear, particularly fresh off a charger at 11.2 Volts). Like all NiMh, they drop in voltage suddenly with little warning from the battery monitor in your gear. Since they are made of button cells with little overcharge tolerance, they typically don't last very long in active use. If you can tell I don't like NiMh 9 Volts, you are dead on the money. Also, there are some real crappy Chinese cheapos from fly by early afternoon companies with exaggerated capacity claims and marginal cells.
As others have suggested, the LiIon 9 Volts from iPower and others are a much better choice. People have been using them for many years with generally good results. make sure you use a matching charger from the same company that provided the batteries. My advice, go with the iPowers, batteries and chargers.
Best,
Larry F
Ive been using Soshine Li-ion 9V 650mAh and so far the experience has been good. They Power my Denecke PS1A's all day long. There was an earlier 600mah model which was terrible and prone to failures.
I've purchased NiMH 9v's in the past, used them for about a week before I bought the iPower 520 9v's and I've never looked back. Definitely stay away from NiMH. Lithium batts are lighter and generally last much longer.
