Shastapete
SRc leaked on Dutch site
Lectrosonics SRc product page leaked on Dutch retail site. (Google Cached version)
On facebook's sound mixer group Gordon confirmed:
"SRC will be dual channel, wide band, and have tracking front end like the 411"
and no wide band SM in the works:
"The SM series transmitters are limited to a single block because of the 250Mw output option in the US - the third order intermods are suppressed by a circulating isolator which is limited by physics to the 25Mhz passband. If we make an SM style transmitter wide band, it will be limited to 100mW - making it not very different than the LT. We do not currently have an SM series wide band in development. LT has all the features and then some (IR synch, porgrammable switch) etc."
Derek H
Gordon also went on to say that if there were enough interest in wideband transmitters in the SM package that eventually they would put engineering effort in that direction.
Something tells me there will be plenty of interest in that..
pvanstry
SM wideband is a must. Actors are actually now aware of the small size of the tx and costume is now planning on us having tiny Tx for hidding them in tighter cloths.
Nate C
I am a mainly a Zax user, but my Lectro SMa's are a life saver often due to their small size. These will remain a vital part of my for many years to come.
We are already limited to 100Mw, so a SM in wideband would make every Lectro user in Australia happy.
pvanstry
I very rarely use 250mw, one could keep one or two of the single block units for those times.
Zaxcom trx900lt is pretty small
Nate C
46 minutes ago, LarryF said:
SSM. Very small and wideband.
Larry F
Don't under sell the SSM Larry. It is itty bitty. I didn't realise it was wideband. Still an SM/SMQ transmitter using AA would be appreciated in wideband even limited to 100Mw.
Yes the LT is pretty small, but due to tight skimpy costumes (think cheerleader outfit) on a reoccurring job the best place to hide the transmitter is in the side of the bra under the armpit. The actresses prefer SMa's over LT's or LA's due to comfort factor. It is the width of the TX that makes this my preferred choice in this case.
BAB414
My main issues with the SSM are the TA3 connector and the cell phone battery. I haven't used one yet but I don't want to buy any more lavs just to fit this one type of transmitter. If you come up with an SMQW, I'm buying.
I like SSM due to it has the lemo3 connector which can switch between my zax TX, its battery runs six hours which is great too. My only concern of using it on my last feature was the limited 50mW output,the range is not so stable as SMQV of course,and even though it's so tiny but with the tightened clothes our super hot actress wearing is still just a little bit noticeable but I wouldn't imagine what it gonna looks like if I was using any other TX.
When VRField 2 ??? I'm waiting !
It's a 3 pin Lemo (same as Zaxcom, and maybe some Sennheiser units?) so those mics are regular stock for sound shops.
The TA connector is too large for the SSM. Heck, it seems to *just* fit inside the SM cases. Similar with the AA battery, it's just too big. Sure, the unusual battery isn't the easiest, so if you need to be able to buy batteries at the supermarket, the SMV is still really darn small.
I think you really need to see and hold a SSM in person to appreciate what Lectrosonics pulled off. The only other transmitter that small that I know of (made by Q5X) doesn't have a removable battery, so the whole unit goes down for charging.
Literally the size of a zippo lighter
Same as Zaxcom,  Sennheiser and Wisycom.
I'm into my second production using a SSM . I haven't noticed any issues with range , I use a Venue Field receiver and SM transmitters. The battery is easily available and not at all expensive , I think it might be commonly used in Fuji cameras. Whilst the size difference between a SSM and a SM might not seem much it makes significant improvements when hiding it in tight costumes and on small people.
BAB414
Ah yes, my mistake. All my lavs are ta5 anyhow. All I currently have are SMs and UMs. If they don't make a wideband SM then maybe I will go for the SSM after all. Is there a multibay charger for the SSM batteries yet?
I too am waiting for the SM style Wideband gear to make the switch, Larry. SSMs are cool, but not having the 250mw or even 100mw in your back pocket in a jam makes it tough.
Agreed, LTs are just too big in this day and age.
WesH
We have a 12-bay 1RU SSM battery charger in production now; once all of the cats are herded (approvals, etc) we will formally announce availability.
Edit:  The 12-up charger is rack mount, as Larry clarifies below.  The model number is CHS12LB50.
Wes Herron
Lectrosonics, Inc.
Edited by WesH
LarryF
15 hours ago, Derek H said:
11 hours ago, BAB414 said:
Wes Herron
Lectrosonics, Inc.
Also, it is rack mount.
Lef
There is a Lemo to TA5 adapter available from Lectro so you can use previously wired lavaliers.
Lef
LarryF
Hi Jack,
Sorry, I'm in a hotel in Vegas and can't get the info. Maybe Wes or Gordon can chime in with links.
Best LEF
WesH
2 hours ago, Jack Norflus said:
Link? Part number?
Hi Jack,
Our part number is MCATA5MLEMO; follow this link to our website for the technical data sheet.  Retail at the usual suspects is around (ouch) $200 -- sorry, that's an expensive little assembly to make.
As usual, we make the wiring diagram available in the technical data sheet for those that are good with soldering irons and enjoy the frustration that comes with soldering tiny connectors.
Best,
Wes Herron
Lectrosonics, Inc.
Edited by WesH
Edit: Removed extra "this" from first sentence.
