echo Posted March 14, 2016 Report Share Posted March 14, 2016 Hey guys, my 411a is draining 9vs very quickly. Lithiums are lasting two hours. Just wondering if anyone has experienced this before? Probably best to send it off to lectro? Quote Link to comment Share on other sites More sharing options...
Glen Deakin Posted March 14, 2016 Report Share Posted March 14, 2016 No Doesn't sound right. Send it in. Quote Link to comment Share on other sites More sharing options...
Gordonmoore1 Posted March 15, 2016 Report Share Posted March 15, 2016 That's an exceptionally high current drain - try it with alkaline - if it behaves properly with them, the lithium's might be imitations. Quote Link to comment Share on other sites More sharing options...
LarryF Posted March 15, 2016 Report Share Posted March 15, 2016 Almost sounds like NiCad or NiMh 9 Volts, not lithiums. As Gordon suggested, try Eveready 9 Volts. They are the best at high drain. If the units are indeed pulling high currents, you should get 1 to 1 and 1/2 hours of life. The 411 should be getting warm also. Make sure both batteries are being drained. If only one battery is making contact, you will get very short life. Simply switch battery positions to see if one battery is undrained or use a Voltmeter on the "drained" batteries to see if both are at the same low voltage, 7.5 Volts or less unloaded. Best, Larry F Quote Link to comment Share on other sites More sharing options...
