Glen Deakin Posted April 25, 2016 Report Share Posted April 25, 2016 Starting this so we don't need to hijack wts thread. Battery eliminators for the 742? External battery packs. Let's list them here. Quote Link to comment Share on other sites More sharing options...
Sam Kashefi Posted April 26, 2016 Report Share Posted April 26, 2016 AA Battery eliminator : http://www.batteryeliminatorstore.com/ Battery : http://www.amazon.com/gp/product/B00Z9QVE4Q/ref=pd_lpo_sbs_dp_ss_2?pf_rd_p=1944687662&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B009USAJCC&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=1AK6S4GGXB3JSD47RQE0 Quote Link to comment Share on other sites More sharing options...
Glen Deakin Posted April 26, 2016 Author Report Share Posted April 26, 2016 With that you have the option of going back to regular batteries if need be. Quote Link to comment Share on other sites More sharing options...
soundtrane Posted April 26, 2016 Report Share Posted April 26, 2016 4.2V 6A Li-Ion NKK self-illuminated slide switch Anodised Aluminum body, magnets to attach to 742 5.5 hours with SuperCMIT and TRX742 The 742 can be used with AA batts as well, no change to the battery compartment Field tested (last 5 days of shoot) Quote Link to comment Share on other sites More sharing options...
Matthias Richter Posted May 1, 2016 Report Share Posted May 1, 2016 On 26.4.2016 at 3:21 AM, Sam Kashefi said: AA Battery eliminator : http://www.batteryeliminatorstore.com/ Battery : http://www.amazon.com/gp/product/B00Z9QVE4Q/ref=pd_lpo_sbs_dp_ss_2?pf_rd_p=1944687662&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B009USAJCC&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=1AK6S4GGXB3JSD47RQE0 so the 742 is fine getting 5V instead of 4.5V as from standard batteries? Quote Link to comment Share on other sites More sharing options...
stacysound Posted May 5, 2016 Report Share Posted May 5, 2016 On April 26, 2016 at 8:21 PM, Sam Kashefi said: AA Battery eliminator : http://www.batteryeliminatorstore.com/ Battery : http://www.amazon.com/gp/product/B00Z9QVE4Q/ref=pd_lpo_sbs_dp_ss_2?pf_rd_p=1944687662&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B009USAJCC&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=1AK6S4GGXB3JSD47RQE0 So you obviously wired your own. Did you get one active and 2 dummies? I haven't found info on which tabs on the 742 gets voltage. I have a BDS with a USB output and I want to plug this into that. Elaborate if you can. Quote Link to comment Share on other sites More sharing options...
Sam Kashefi Posted May 6, 2016 Report Share Posted May 6, 2016 I have 3 AA Cells, one 5VDC and two dummies. Just use red and black wire for pin 1&4. Quote Link to comment Share on other sites More sharing options...
stacysound Posted May 6, 2016 Report Share Posted May 6, 2016 6 hours ago, Sam Kashefi said: I have 3 AA Cells, one 5VDC and two dummies. Just use red and black wire for pin 1&4. Good to know. Thanks. On the "batteries" do you have to make series connections between the 3, or just drop in 1 active and 2 dummies? Quote Link to comment Share on other sites More sharing options...
soundtrane Posted May 7, 2016 Report Share Posted May 7, 2016 http://tascam.com/product/bp-6aa/specifications/ Quote Link to comment Share on other sites More sharing options...
Matthias Richter Posted June 4, 2016 Report Share Posted June 4, 2016 using pretty much Sam's setup now. Works very nice. Battery pack was 15€. Just bought 4. They last around 4-5hours with a SCMIT. Only thing is: the RXs display will always show full TX-battery (R9) so the BoomOp needs to check the batt himself. Will just change regulary to avoid sudden death. is that the same with you guys? Quote Link to comment Share on other sites More sharing options...
stacysound Posted June 8, 2016 Report Share Posted June 8, 2016 I built this up thanks to Sam's guidance. Plugged it into my BDS box that has a USB port for charging the phone, and it worked great. Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted August 26, 2016 Report Share Posted August 26, 2016 I need something that will work 10 hours. Any ideas? Quote Link to comment Share on other sites More sharing options...
Jason Todd Posted August 26, 2016 Report Share Posted August 26, 2016 I'm also interested in a 10 hr solution. Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted August 26, 2016 Report Share Posted August 26, 2016 1 hour ago, RadoStefanov said: I need something that will work 10 hours. Any ideas? http://www.all-battery.com/li-polyerbatterypacks.aspx Quote Link to comment Share on other sites More sharing options...
Matthias Richter Posted August 26, 2016 Report Share Posted August 26, 2016 and you wanna have that on the pole?? My battpack (6700mAH) will last 4-5h. There are 10AH and more available but it gets heavy ... Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted August 27, 2016 Report Share Posted August 27, 2016 4 hours ago, Matthias Richter said: and you wanna have that on the pole?? My battpack (6700mAH) will last 4-5h. There are 10AH and more available but it gets heavy ... I want to run 2 booms for dual sit down interviews and court rooms. I use 2 denecke Phantom going in to a stereo trx900LAS but a trx742 with a longer battery will free me from worrying. Quote Link to comment Share on other sites More sharing options...
Wandering Ear Posted August 27, 2016 Report Share Posted August 27, 2016 Rado, I'm curious why you want to do sit down interviews wirelessly instead of hardwired? Quote Link to comment Share on other sites More sharing options...
Matthias Richter Posted August 27, 2016 Report Share Posted August 27, 2016 a powerpack like this and the mentioned AA dummies will last probably 15h: https://www.amazon.de/dp/B01FM6TOH6?psc=1 Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted August 27, 2016 Report Share Posted August 27, 2016 I want stay away from USB . I want some sort of locking connector battery.... Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted August 28, 2016 Report Share Posted August 28, 2016 4 hours ago, Wandering Ear said: Rado, I'm curious why you want to do sit down interviews wirelessly instead of hardwired? Easier Quicker Setup. One TRX742 for 2 booms. Places where running wires is not permitted or impossible. It works great for a court room. Quote Link to comment Share on other sites More sharing options...
RadoStefanov Posted December 27, 2016 Report Share Posted December 27, 2016 After my recommendation battery eliminator store designed and started selling USB connected AA battery eliminators. 2AA "Utilizes our custom AA battery cells, one Active and one Dummy (shorted) to complete the circuit in your 2 AA cell battery tray. Connects to USB port on a phone charger, computer, or portable USB battery pack. Converts USB bus power (5.1 Volts) to 3 Volts DC. Maximum current is determined by the capabilities of your USB port. Phone chargers are often rated to 1 Amp maximum, while tablet chargers are often 2.1 Amps maximum." 3AA "Utilizes our custom AA battery cells, one Active and two Dummy (shorted) to complete the circuit in your 3 AA cell battery tray. Connects to USB port on a phone charger, computer, or portable USB battery pack. Converts USB bus power (5.1 Volts) to 4.5 Volts DC. Maximum current is determined by the capabilities of your USB port. Phone chargers are often rated to 1 Amp maximum, while tablet chargers are often 2.1 Amps maximum." http://www.batteryeliminatorstore.com/index.php?id_category=10&controller=category Quote Link to comment Share on other sites More sharing options...
