Solid Goldberger Posted May 13, 2016 Report Share Posted May 13, 2016 Hi Everyone, I'm looking for recommendations for a quality DA/splitter for a pair of consumer RCA audio signals. Simply, I'm just looking to split the analog output of an music device with no signal degradation, assuming thats possible. I'd love to not spend hundreds of dollars if possible, though if there are great models that are pricey I'd love to know about those as well. Thanks in advance, e. Quote Link to comment Share on other sites More sharing options...
Gerard-NYNY Posted May 14, 2016 Report Share Posted May 14, 2016 I bet Sescom makes a box or cabled transformer/splitter thingy for that. If nothing they currently manufacture is perfect for you there's usually plenty of their discontinued items floating around on Ebay. Quote Link to comment Share on other sites More sharing options...
Wandering Ear Posted May 14, 2016 Report Share Posted May 14, 2016 ART audio makes one too. Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted May 14, 2016 Report Share Posted May 14, 2016 RDL Quote Link to comment Share on other sites More sharing options...
Solid Goldberger Posted May 14, 2016 Author Report Share Posted May 14, 2016 It looks like a lot of these are available locally at B&H, so I'll pick one up and give it a listen. Thanks for the recs! e. Quote Link to comment Share on other sites More sharing options...
Rick Reineke Posted May 14, 2016 Report Share Posted May 14, 2016 The Rolls DA134 seems to be the most economical @ $98. The stated specs look decent and it has 4 outputs (stereo) and 8 mono, via hard wired stereo/mono switch. It also has gain pots on the outputs, and states, "Can raise the output level to true line level for any output". (I guess 'true' line level to Rolls is max. +12dB) The max input is +12dB as well. Runs on 15V, so our external battery systems would probably run it if need be. Quote Link to comment Share on other sites More sharing options...
