spaulgal Posted June 29, 2016 Report Share Posted June 29, 2016 What's the cleanest and most straight forward way to get dual k41's into an M10 for recording? I'd rather not have an add'l box if necessary. May I be better off using a DR100 for this purpose? Thanks! Quote Link to comment Share on other sites More sharing options...
chrismedr Posted July 2, 2016 Report Share Posted July 2, 2016 the Sony M10 seems to have neither XLR nor phantom power (correct me if I'm missing something)... so either add a small mixer (like the MixPre) or if you need to keep things really small then as you say use a DR100 or H5 or similar. chris Quote Link to comment Share on other sites More sharing options...
Crussell Posted July 8, 2016 Report Share Posted July 8, 2016 You're probably going to need an additional box in either case. The M-10 can't provide phantom power so you'll need a MixPre as Chris said. And the DR-100 blows through batteries with two phantom powered mics so you'll need some sort of powering setup. Quote Link to comment Share on other sites More sharing options...
