azw Posted July 9, 2016 Report Share Posted July 9, 2016 Be advised - an ERX feeding an Amira will experience intermittent link status on the ERX if the camera's Bluetooth is on. To the Bluetooth off, use the side setup menu, not the one in the eyepiece. azw Quote Link to comment Share on other sites More sharing options...
Nate C Posted July 10, 2016 Report Share Posted July 10, 2016 Thanks for the heads up. I had intermittent signal at close range at a gear check yesterday. Due to a really short a lotted time, other issues and having worked successfully with this particular camera before I dismissed it to a bad Freq. Luckily first day of production is mostly non sync playback. Hopefully all runs smooth but sharing another potential problem is appreciated. Quote Link to comment Share on other sites More sharing options...
