Matthias Richter
TRXLA2.6 no Audio signal
With what Rado said, check the pins in the Transmitter's Lemo connector.  It has been known to happen that a pin gets pushed down into the connector housing and no longer makes proper contact.
If the transmitter shows normal audio levels with a lav plugged in, and the qrx shows signal strength but red light ln the antenna status, it may be your synth chip. Mine went out earlier this month in my trx900LT, factory reset actually screwed me because I had a work aound but after the factory reset it would not work at all.
3 hours ago, Matthias Richter said:
Thanks for the tip! Just checked and all 3 pins are on show right on the top of the housing.
hear, but don't listen to Rado all the time ;)
1 hour ago, efksound said:
IMHO The best and easier way would be to try with another lav to be sure if it is the lav or the TRX.
thats what I did first of course! Because normally it´s the actor ribbing the lav of or something. No "luck" this time.
Howy´s sent me an email how to load the settings from that receiver´s SD-card. Will try 2moro.
This happened to me as well. Exact same issue with the synth chip. Had to send in to Zax to fix.
