Philip Perkins Posted August 22, 2016 Report Share Posted August 22, 2016 Can anyone suggest an off-the-shelf right angle (adjustable) TA3F field-serviceable connector that doesn't require an endoscope and a mechanical engineering degree to deploy? Have tried two versions from Usual Suspects, very expensive per each, hated them, to big too fragile too fussy. This is for a bespoke setup so I need to solder them myself (re a Kortwich commission). Is the only solution to hack up straight connectors and epoxy them up? I'd like something that I could change the cable-exit angle on in the future, as well as repair if they get damaged. thx Quote Link to comment Share on other sites More sharing options...
Constantin Posted August 22, 2016 Report Share Posted August 22, 2016 I can only think of those by Remote Audio. Surely you've tried them when you say "usual suspects"? They certainly seem to meet all of your requirements Quote Link to comment Share on other sites More sharing options...
efksound Posted August 22, 2016 Report Share Posted August 22, 2016 I think if you contact Eric Toline at PSS Florida he might have what you are looking for Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted August 22, 2016 Author Report Share Posted August 22, 2016 Thanks, I'll ask. But I want raw connectors, not custom-built cables. Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted August 22, 2016 Report Share Posted August 22, 2016 Sorry Philip raw connectors are not available. Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted August 23, 2016 Author Report Share Posted August 23, 2016 Bummer dude. Quote Link to comment Share on other sites More sharing options...
nickreich Posted August 23, 2016 Report Share Posted August 23, 2016 you might be able to buy the right-angle caps direct from efksound in spain when he gets back from holidays in September - I'm keeping an eye on his FB page as I want some too Quote Link to comment Share on other sites More sharing options...
Constantin Posted August 23, 2016 Report Share Posted August 23, 2016 Thanks, I'll ask. But I want raw connectors, not custom-built cables. Remote Audio is no fit? Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted August 23, 2016 Report Share Posted August 23, 2016 13 hours ago, Philip Perkins said: Bummer dude. The connectors in the pictures are standard REAN TA's with out the rubber boot. The caps with our "PSS" on them were custom made for us by EFK sound. Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted August 23, 2016 Report Share Posted August 23, 2016 I'm guessing, Philip, that you've also checked out the ones Lectrosonics sells? Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted August 23, 2016 Report Share Posted August 23, 2016 You really don't want the RA TA assemblys from Lectro called the "RATPACK." The set screws that hold the connector in place are always coming loose. Here's the RATPACK from Lectro. $48 each. Quote Link to comment Share on other sites More sharing options...
Pat Slater Posted August 23, 2016 Report Share Posted August 23, 2016 Apart from the price of the Lectro RATPACK I have found them great. As far as the set screws go, nothing a drop off nail polish won't hold. Quote Link to comment Share on other sites More sharing options...
soundtrane Posted August 23, 2016 Report Share Posted August 23, 2016 or loctite blue... Quote Link to comment Share on other sites More sharing options...
Eric Toline Posted August 23, 2016 Report Share Posted August 23, 2016 I find that the set screws really can't hold the insert firmly in place. Tightening the set screws down to lock the insert in place is almost impossible considering the extra small Allen wrench that is supplied and forget any field adjustment that might be required. Quote Link to comment Share on other sites More sharing options...
NateWBS Posted September 6, 2016 Report Share Posted September 6, 2016 Ambient have this available now: http://ambient.de/en/product/ta3f90l/ It appeares to be a modded Rean that can be re-used. Quote Link to comment Share on other sites More sharing options...
johnpaul215 Posted September 6, 2016 Report Share Posted September 6, 2016 Has anyone used the Remote Audio ones yet? I saw them at NAB, but I haven't heard any first hand field reports. Quote Link to comment Share on other sites More sharing options...
Philip Perkins Posted September 6, 2016 Author Report Share Posted September 6, 2016 I bought some (expensive). I don't like them at all, I'm not smart or dexterous enough to successfully work them myself, kind of big, like the ones Lectro sells. Redding has some new ones incoming that look better. Quote Link to comment Share on other sites More sharing options...
joy Posted September 6, 2016 Report Share Posted September 6, 2016 I did it myself. Quote Link to comment Share on other sites More sharing options...
Derek H Posted September 6, 2016 Report Share Posted September 6, 2016 Nice, Joy. Looks like a BNC ra body? Philip, try Gene at audio department. They have something. Not sure if they sell the parts. Quote Link to comment Share on other sites More sharing options...
joy Posted September 6, 2016 Report Share Posted September 6, 2016 Not RA body BNC. It may be a machine tool or a similar device. Use for connecting tubing. 10 mm in diameter (M10), very cheap, I bought in China, only need about $0.3.Ta3 or TA5 can be installed directly. But there is a problem, there are little, may need to drill, the inside of the hole enlargement point. Quote Link to comment Share on other sites More sharing options...
johnpaul215 Posted September 9, 2016 Report Share Posted September 9, 2016 On September 6, 2016 at 3:33 PM, joy said: Not RA body BNC. It may be a machine tool or a similar device. Use for connecting tubing. 10 mm in diameter (M10), very cheap, I bought in China, only need about $0.3.Ta3 or TA5 can be installed directly. But there is a problem, there are little, may need to drill, the inside of the hole enlargement point. I like this idea! Quote Link to comment Share on other sites More sharing options...
Shastapete Posted September 11, 2016 Report Share Posted September 11, 2016 On 9/6/2016 at 3:33 PM, joy said: Not RA body BNC. It may be a machine tool or a similar device. Use for connecting tubing. 10 mm in diameter (M10), very cheap, I bought in China, only need about $0.3.Ta3 or TA5 can be installed directly. But there is a problem, there are little, may need to drill, the inside of the hole enlargement point. Where did you order these from? they look great Quote Link to comment Share on other sites More sharing options...
joy Posted September 11, 2016 Report Share Posted September 11, 2016 I bought in an industrial machine tool accessories shop. Quote Link to comment Share on other sites More sharing options...
Jack Norflus Posted October 31, 2016 Report Share Posted October 31, 2016 I saw these the other day and they don't suck. http://www.cabletechniques.com/lopro-xlr-mini-xlr Quote Link to comment Share on other sites More sharing options...
chrismedr Posted November 1, 2016 Report Share Posted November 1, 2016 1 hour ago, Jack Norflus said: I saw these the other day and they don't suck. http://www.cabletechniques.com/lopro-xlr-mini-xlr they look very similar (the same?) as the ambient ones mentioned earlier on. no experience with them though, I still think that Kortwich makes the slickest right angle TA3 and XLR connectors (they are pre soldered though) Quote Link to comment Share on other sites More sharing options...
