soundtrane Posted September 1, 2016 Report Share Posted September 1, 2016 On 8/26/2016 at 2:47 AM, John Blankenship said: Why? I'm guessing a screwdriver would make entry obtainable. I have opened one of these sometime ago - maybe couple of years ago - and fixed an issue with it. I dont think there is really any space in there for a voltmeter. if i can dig up photos (i always take photos of opened up gear!), i will post it here... Quote Link to comment Share on other sites More sharing options...
MartinTheMixer Posted September 1, 2016 Report Share Posted September 1, 2016 22 minutes ago, soundtrane said: I have opened one of these sometime ago - maybe couple of years ago - and fixed an issue with it. I dont think there is really any space in there for a voltmeter. if i can dig up photos (i always take photos of opened up gear!), i will post it here... You wouldn't need to mount the voltmeter inside would you? Just the wires leading to the voltmeter. Or am I not seeing something here? Quote Link to comment Share on other sites More sharing options...
soundtrane Posted September 1, 2016 Report Share Posted September 1, 2016 Well, you can mount a small VM on the outside on the side. I am sure you can do that. but to mount a VM flush against the surface may not be possible. Imho - electronics experts here - please correct me if i am wrong - regulated is ok if the load is not going to draw MORE current that the regulating circuit can handle. Other than that - a small voltage drop maybe which is not so bad as Jeff mentioned early into this thread... Other caveats have already been mentioned - battery capacity cant be seen on the other side, etc. However there maybe workarounds (i think there ARE!)... my 2 cents... Quote Link to comment Share on other sites More sharing options...
John Blankenship Posted September 1, 2016 Report Share Posted September 1, 2016 58 minutes ago, soundtrane said: I have opened one of these sometime ago - maybe couple of years ago - and fixed an issue with it. I dont think there is really any space in there for a voltmeter. if i can dig up photos (i always take photos of opened up gear!), i will post it here... Like was mentioned, I was thinking that someone could run a cable out through a small hole and mount a voltage meter somewhere handy. Some seem to challenge this concept. My response was simply a solution for someone who lamented that a voltmeter across the output of a regulated supply would not show battery voltage. If, indeed, tapping a couple of leads off the primary of the voltage regulator is too daunting a project, then please disregard my comments. Quote Link to comment Share on other sites More sharing options...
MartinTheMixer Posted September 1, 2016 Report Share Posted September 1, 2016 18 minutes ago, soundtrane said: Well, you can mount a small VM on the outside on the side. I am sure you can do that. but to mount a VM flush against the surface may not be possible. Imho - electronics experts here - please correct me if i am wrong - regulated is ok if the load is not going to draw MORE current that the regulating circuit can handle. Other than that - a small voltage drop maybe which is not so bad as Jeff mentioned early into this thread... Other caveats have already been mentioned - battery capacity cant be seen on the other side, etc. However there maybe workarounds (i think there ARE!)... my 2 cents... Well, you have loss when you convert things. If you don't need to regulate, then you don't regulate. In our world, this sounds scary because you are working, all is great and then BAM, you no longer have the voltage you thought you had. Quote Link to comment Share on other sites More sharing options...
Masaki Hatsui Posted September 4, 2016 Report Share Posted September 4, 2016 If it is only the Tascam needs to feed a regulated 12V, I'd rather put a regulator next to DR680. I really don't know that recorder but according to the picture I found on the net, maybe you can even put a small regulator inside the box... https://www.gearslutz.com/board/9310017-post25.html Quote Link to comment Share on other sites More sharing options...
