Pete D Report post #26 Posted November 8, 2016 From Rycote's Instagram: Looks interesting but doesn't seem to leave much room for wind protection. I feel like even a foam windscreen would have to be a pretty exact size to fit, nevermind trying to use that with a softie. Share this post Link to post Share on other sites
Derek H Report post #27 Posted November 8, 2016 Yeah that looks like a bad design to me, even the foam will bump the lyres. Unless I'm missing something. Share this post Link to post Share on other sites
VAS Report post #28 Posted November 8, 2016 This is a bad design. Share this post Link to post Share on other sites
RadoStefanov Report post #29 Posted November 8, 2016 what else do you expect from rycote? inv6 with gray lyre might work... Share this post Link to post Share on other sites
Jesse Flaitz Report post #30 Posted November 8, 2016 I like where their head is at but... yeah. Fail. Share this post Link to post Share on other sites
Derek H Report post #31 Posted November 8, 2016 I'm sure Cinela will do something. Pianissimo looks like a good fit for outdoor use. Share this post Link to post Share on other sites
Constantin Report post #32 Posted November 8, 2016 That Rycote thing does look a bit weird. Maybe the mic holder thing can go in the middle, between the two Lyre types? That would make a bit more sense Share this post Link to post Share on other sites
Philip Perkins Report post #33 Posted November 8, 2016 Couldn't you slide the mic forward in the mount so the lyres clear the vents? The a small foamie wold work. Otherwise you'd have to cut the foamie in half, with the back section between the lyres. The 3rd, rear "grabber" thing looks odd to me--like it would transmit a lot of boom noise to the mic? Share this post Link to post Share on other sites
Jim Feeley Report post #34 Posted November 8, 2016 Maybe the picture of the Rycote mount has a funky perspective and the distance from the lyres to the barrel is more like this: Share this post Link to post Share on other sites
daniel Report post #35 Posted November 8, 2016 3 hours ago, RadoStefanov said: what else do you expect from rycote? inv6 with gray lyre might work... Generally a good value solution and when things haven't quite hit the mark their customer service has been excellent (for UK buyers at least). Ie. an improved component/upgrade has been sent FOC. The "grabber" has little to do with the transmission of boom noise (so long as it grabs the mic securely), it's all about the suspension between the fixing points. In my experience with lyres, most of the suspension movement takes place before the inner radius and the mic is axially very stable. Ie. it'll move back and forth with the outer radius flexing the most and distance between the mic and the inner radius of the suspension remains quite constant especially when there is an armature between between the "grabbers" like this 1 (and the softy invision). If the mic banged the the lyres in operation they could have gone with a mic "grabber" attached to 1/4" thread of the handheld recorder suspension which has inverted lyres. http://rycote.com/microphone-windshield-shock-mount/portable-recorder/ The only way to know for sure is to try 1 (but conjecture is fun). Share this post Link to post Share on other sites
pkautzsch Report post #36 Posted November 8, 2016 Indeed, the mic is being held at the very end by that strange-looking solid mic clip. Looking closely, the lyres only hold the pair of rods that on the other end has the actual mic clip. The same principle, just with a nicer design IMHO, has been in use for decades in the original Neumann KMR suspensions. The advantage of this concept is that no part of the interference tube ports is blocked by a mic clip - with those tiny Rycote clips this might rather be a theoretical issue however. A foam windscreen would indeed touch the lyres. To enable windscreen use, the lyres would have to be upside down like in the "shaver recorder" suspensions. However, both the "INV-6 with grey lyres" solution (in my case with CMC 641) and the "cut into the foam windscreen for use with INV-7" approach (in my case with KMR 81 and MKH 416) have successfully been reality tested. So why bother. Share this post Link to post Share on other sites
gpiegari Report post #37 Posted November 8, 2016 This new cantilever Rycote design is similar to the old Lightwave mount which was actually very quiet. Share this post Link to post Share on other sites
Jason Todd Report post #38 Posted November 8, 2016 Have they announced pricing for the mini CMIT Share this post Link to post Share on other sites
chrismedr Report post #39 Posted November 8, 2016 18 minutes ago, Jason Todd said: Have they announced pricing for the mini CMIT in the video they mention 1690EUR + tax. just seen it on a UK website for 1366GBP+VAT while at the same place the CMIT 5U is listet at 1412GBP+VAT, so I think it's likely it will be some 50EUR/GBP/USD under the 5U in most places. ps: for comparison: the 4017C is 955GBP+VAT and the 8060 is 605GBP+VAT. all lovely mics : ) Share this post Link to post Share on other sites
Jim Feeley Report post #40 Posted November 9, 2016 55 minutes ago, Jason Todd said: Have they announced pricing for the mini CMIT A couple of the reliable usual suspect USA dealers show it selling for US$1999. And expected to be in stock in December. Share this post Link to post Share on other sites
Jason Todd Report post #41 Posted November 9, 2016 Nice. Thanks! Share this post Link to post Share on other sites
Masaki Hatsui Report post #42 Posted November 13, 2016 This one is a DPA 4017C competitor. 4017C is 154 mm long while MiniCMIT is 151 on their website. Below is my modded Rycote suspension for DPA4017C, for the moment for interior use only, which works quite well. Windscreen version (shorter than WS1) is coming... Hopefully Cinela will coming with a sophisticated solution for these shorten microphone bodies. I was not convinced their answer with Pianissimo to DPA 4017C, because of its final volume, and non compatibility of use without basket. And now that Schoeps makes a miniatured body, how about to make a MiniCMC with interchangeable capsules Masaki Share this post Link to post Share on other sites
chriswoolf Report post #43 Posted November 15, 2016 It is most amusing to see the comments, based on a single "design concept" picture... First of all, let me tell you all that this mount was designed in conjunction with Schoeps. Rycote has had an excellent long-term cooperative relationship with Durlach, and the companies shared 3D CAD files to enable this product to go ahead. A new version of lyre was designed specifically for the CMITmini mount and there is ample room for the 50mm diameter foam to fit, with plenty of wiggle room. The distance between lyre tips is 64mm. With short-bodied microphones there is very little "meat" to hang on to, so conventional clip arrangements are difficult to use. Masaki's system can work, but it is very dependent on the XLR fitting extremely firmly - any movement at the joint will be heard as creaking. It is the sort of method that an individual can control, but not something a manufacturer would be wise to use. The new cam-lever clamp allows the microphone to be held extremely securely - slide the mic in, drop the lever fully down, and there is no movement whatsoever. You can wave the microphone as vigorously as you like and nothing wobbles or shifts. The rigid clamp and stainless rods are necessary to give the proper mass transfer. Lyres are very flexible and efficient, but as with all sprung systems - it doesn't matter what design they are - the loading must be substantially the same on them to allow uniform orthogonal movement. Think what happens to the handling of a car when the spring loading is drastically uneven. In effect the lyres are clipped to the microphone at optimal positions, but without any clips being required - the grille slots are entirely free, yet the mic is balanced and secure. I do accept that I have had the great advantage of having both virtual and real examples of the CMITmini in my possesion, and the use of an actual prototype mount, so I can speak from experience;}. The mount works very nicely, thank you. And the microphone is an absolute delight too - congratulations to Schoeps. Together, they form a very neat, physically short solution for lightweight indoor pole use. For windier locations there will be related Rycote solutions that are equally compact. Now, I hope this response gets posted... Chris Woolf (with his Rycote designer hat on) Share this post Link to post Share on other sites
soundtrane Report post #44 Posted November 15, 2016 <the grille slots are entirely free> Dear Chris, the photo shows one of the lyres right at the middle of the grills on the mic. This may be confusing? Share this post Link to post Share on other sites
Matthias Richter Report post #45 Posted November 15, 2016 its misleading I believe. The lyre is actually not touching the mic at all. Right? Share this post Link to post Share on other sites
Christian Spaeth Report post #46 Posted November 15, 2016 Interesting new concept, Chris. Eager to try it! Share this post Link to post Share on other sites
Simon Davies Report post #47 Posted November 15, 2016 The slots are completely clear (the attached shows a 50mm diameter foam fitted)... the Lyre is just under 80mm across. Share this post Link to post Share on other sites
daniel Report post #48 Posted November 15, 2016 Looks really tidy. Thanks for the clarifications. Share this post Link to post Share on other sites
soundtrane Report post #49 Posted November 16, 2016 Simon, thanks for the pictures, clears everything... Share this post Link to post Share on other sites
WinstonC Report post #50 Posted November 16, 2016 That's a super clean design! At 80mm clearance to the Lyre, there is no room for a Super Softie so yes, it is indoors only or calm day. Looking forward to seeing how this mount is adapted to a Cyclone, or another design to accommodate a Super Softie Share this post Link to post Share on other sites
