ProgressiveDrum
Waves Broadcast and Production
Used an earlier version of RX in the past and didn't care for it but RX 5 is fantastic. We fired waves also:). Once Izotope figured out the workflow to make RX available in Protools as a standalone application (RX connect and monitor) it became a wonderful tool to use.
FWIW, RX also does automatic round-trips in Nuendo. I love that I can use the same RX algorithms as a clip-based VST process, on a channel insert, and with the Connect passing to the full-on app. You can apply as much or as little tweaking as you think an element requires. Flexibility is a good thing.
Not to derail the thread too much but I do have a question for other RX users. I had RX 3 and really found it not very useful at all. Tasks that apparently worked like magic on the Youtube demos eluded me. When we bought RX 5 advanced I was skeptical but quickly learned that it was doing pretty much what I wanted it to do. I used RX 3 as plug-ins in audio suite and RX 5 as stand-alone. Am I imagining things or is the processing quality of the RX 5 advancedstand alone mode vastly superior to the plug in version?
IIRC (my studio is temporarily down), RX5 gives you a lot more automatic, learning, and self-configuring options. So depending on which UI you're using, it could very well be that RX5 has better processing... even if the underlying algorithms are similar.
Yeah, I used RX 3 as plug in and use RX5 advanced as standalone (due to the improved workflow) and those automatic, learning and self-configuring options are definitely great but I noticed that in RX 3 spectral repair was not happening for me the way I expected. However, in RX 5 spectral repair works great  and I can get there fast. Hence my suspicion that it could make a difference if I run standalone vs plug in but I haven't tested spectral repair as a plug in yet, had no reason to until this question popped into my head.
I'd suspect the difference you're experiencing is more due to the advancements in the software between RX version 3 and RX version 5 than it is due to the difference between standalone and plugin formats.
-Mike
22 hours ago, Lachlancampbell said:
For audio restoration, there's nothing as good as RX. But I love my Waves Renaissance EQ and Comps.
There actually is, but its quite a bit more expensive. But to your point, Izotope is closing the gap by leaps and bounds. Partly by buying the tech from the ones ahead of them. Cedar
Yeah, good point. They've made the tools very accessible.
RX FTW. Works well in Adobe Audition too. I prefer the round trip option via RX Connect and use standalone application.
Sent from my SM-N9208 using Tapatalk
I bought the waves broadcast bundle before I knew what I was on about... Total waste of money. The only thing I still use out of it is the Rcomp. Definitely don't have a WUP, and won't ever use them again.
RX5 is fantastic. Spectral repair tools, dialog denoiser, and the automated "signal chains" are unbelievably good. The least useful tool IMO is de-reverb.
I received an email from Izotope today announcing that RX 6 is due to be released on 4/20.
RX 6 is coming April 20th!
Built on years of extensive research in advanced digital signal processing and machine learning, RX 6 features cutting-edge technologies for post production like lav mic de-rustle, dialogue isolation, and low-end wind rumble removal. It also introduces creative approaches to age-old music recording problems like microphone bleed, sibilance, mouth clicks, and breaths. With version 6, RX advances to the next level of audio repair that once seemed impossible.
Get a sneak preview of RX 6 and sign up for a Westlake Pro webinar that will be live streamed on April 20th.
