Jeremiah Sheets
Lectro firmware update?
14 posts in this topic
I'm pretty sure you have to send them back to lectro to have firmware updates done.
This is what I figured, but I thought I recalled seeing what looked like a USB port on some of the units.
The manual for the LT says you need a windows machine.
Manuals = great shitter material
Not sure about Src but have LT/LR can be done via USB port.......... updates and updater available at Lectro website.
There is a Mac version of the updater now too
I hope they add some way to USB firmware updates on an SRc, maybe a special back plate?
Isn't it possible to update the fw on the SRc with LectroLink anymore, like on the SRa and SRb ?
http://www.lectrosonics.com/Support/Table/Wireless-Firmware-Current-Products/Receivers/
Created: 13 April 2016
SRc Firmware Revision History
This model is not capable of firmware updates in the field so no files are available for download. Contact Lectrosonics if you need a firmware update.
SRc v1.07 - 20 September 2016
When the BACK button is used to stop a scan in progress, the first receiver's channel is now properly restored to its pre-scan value.
In the receiver tuning pages, Menu+Up and Menu+Down now adjust the frequency by 1.6 MHz (a single hex code digit, the same as the SRB) instead of 6.4 MHz (four hex code digits, as with earlier versions of SRC firmware).
SRc v1.06 - 22 June 2016
Fixed a bug (affecting A1 band units only) wherein the Smart Tune function didn't always choose the quietest frequency.
Periodic information messages like "check frequency" no longer interrupt Tune or Scan functions.
Single step tuning in user group entry mode (for groups U and V) now consistently conforms to the selected step size, instead of sometimes permitting 25 kHz steps when the 100 kHz step size was selected.
SRc v1.05 - 07 April 2016
First production release.
You can update any Lectrosonics SR , SRA, SRB or SRC with the Lectro Link you just need the firmware file.
Hmm... I'm curious why Lectrosonics says it cannot be performed in the field. Whitney, have you tried this with the SRc?
No But on the website it says you cannot field update SR or SRB which is not correct if you have the Lectro Link update interface ( Which I own) you just need the right HEX file to do the update.
Anybody have a link or source for this lectro-link interface? I can't find any information online.
Any Lectro dealer should be able to get one for you. You need a PC the correct HEX file and the update Utility. You remove the cover on SR and plug in a special cable then update. You can also update a few other products too but not all of them I have had for many years
http://www.pro-sound.com/p/lectrosonics-lectrolink-firmware-adapter-and-freq-utility-tool.html
