35 posts in this topic
I like swappable batts so generally go w/ Moze etc if I don't need genlock.  But I got a brace of Tentacles anyhow partly because they appealed to me as a nice piece of practical design and partly because some Steadi- and gimble etc folks ask for them by name.  Can't argue with the weight.....
Btw, a little ot. How do you usually set timecode on set?  Is it tod or from 01 hour?
ToD unless it is likely that we will work through midnight
In which case I'll do TOD -12
Yes ToD -12, but there are some clients where I want everyone to know we been working for too many hours and we are not done yet
Can someone enlighten me why / when / what situations going over midnight will cause a problem?
If all is well, the user bits contain the date, so there should be no issues.
(Yes, that's theory. And as we all know, in theory there is no difference between theory and practice. In practice however...)
Bouke
1) Typically, this is a question for post as to their preference...
2) If post isn't assigned yet, ask the producer...
3) If the producer is clueless, use either minus (or plus) 12, or start from zero (as Al mentioned), to clock work time.
It won't cause a problem. But if you use autosync, all files created after midnight will appear in your timeline before the files recorded earlier. No big deal, but it's also no big deal for me to change the clock.
Also, since I change the clock of my recorder (and TC follows that), the recorder won't create a new folder for the new day
Bouke
Typically, though dependent on the specific recorder you're using, user bits don't automatically change at midnight. But when using TOD timecode, the timecode will reset to 00:00:00:00 at midnight. This will lead to takes done past midnight to have earlier timecode then takes done before midnight, and when organizing files in an NLE by timecode, it can lead to confusion.
Having done some post supervision now, I can tell you that it is generally good practice to do TOD minus 12 when doing overnight shoots.
